mobile app and mobile popup
1578
10-25-2013 08:55 AM
RickHendrickson
Hi, I am a little desperate here. Coming from the Silverlight API and struggling with a few things. I am putting together a simple mobile app using the javascript api. I can't for the life of me get the popups to work. I know the data is coming across when the feature layer loads because I can see it in fiddler. But when I click on the feature with a desktop browser the popup appears with no data in it. On a mobile device the popup doesn't even appear. The code is pretty short so I am going to include the whole thing. Can someone let me know if something jumps out at you? Please?
Thanks so much
Rick
<!DOCTYPE html><html>         <head>         <meta name="viewport" content="width=device-width,initial-scale=1,maximum-scale=1,minimum-scale=1,user-scalable=no"         />         <meta name="apple-mobile-web-app-capable" content="yes" />         <meta name="apple-mobile-web-app-status-bar-style" content="black-translucent">         <title>             Campus Utilities         </title>         <!-- <link href="https://community.esri.com//ajax.googleapis.com/ajax/libs/dojo/1.9.1/dojox/mobile/themes/iphone/iphone.css"         rel="stylesheet"></link>-->         <link rel="stylesheet" href="http://jsdev.arcgis.com/3.7/js/esri/css/esri.css">         <link rel="stylesheet" type='text/css' href='http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/esri/dijit/css/Popup.css'         />         <link rel="stylesheet" type='text/css' href='http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/esri/dijit/css/PopupMobile.css'         />         <!-- css used to customize the UI of the application -->         <link rel="stylesheet" href="css/main.css" />         <!-- stylesheet will go here -->         <!-- dojo/javascript will go here -->         <!--not sure if i need this??-->         <script>         var dojoConfig = {     mblAlwaysHideAddressBar: true     };         </script>         <script type="text/javascript" src="dojox/mobile/deviceTheme.js" data-dojo-config="mblThemeFiles: ['base','Accordion']"         , data-dojo-config="async:true">         </script>         <script src="http://jsdev.arcgis.com/3.7compact/">         </script>         <script>             // Load the widget parser and mobile base     require(["dojox/mobile/parser", "dojox/mobile/deviceTheme", "dojox/mobile", "dojox/mobile/View", "dojox/mobile/ContentPane", "esri/InfoTemplate", "esri/map", "esri/dijit/PopupMobile", "esri/dijit/PopupTemplate", "esri/layers/FeatureLayer", "esri/sniff", "dojox/mobile/ToolBarButton", "dojo/on", "esri/layers/FeatureLayer", "esri/dijit/Legend", "dojo/domReady!"], function(parser, deviceTheme, on, Map, dom, registry, mobile, has, PopupMobile, PopupTemplate, FeatureLayer, InfoTemplate) {         // Parse the page for widgets!         parser.parse();                   var popup = new esri.dijit.PopupMobile(null, dojo.create("div"));                   var map = new esri.Map("map", {             basemap: "satellite",            center: [-98.57, 39.82],              zoom: 4,             slider: false,             extent: initExtent,             infoWindow: popup,             isPan: true         });         dojo.place(popup.domNode, map.root);           var IrrigationLines = new esri.layers.FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3", {             mode: esri.layers.FeatureLayer.MODE_ONDEMAND,             infoTemplate: popupTemplate,             outFields: ["*"]         });         //define a popup template           var popupTemplate = new esri.InfoTemplate({            title: "{STATE_NAME}",             fieldInfos: [{                fieldName: "SUB_REGION",                 label: 'SUB_REGION ',                 visible: true             }],             showAttachments: false         });           IrrigationLines.on("click", function(evt) {             map.infoWindow.setFeatures([evt.graphic]);             map.infoWindow.show(evt.mapPoint);         })         map.addLayers([IrrigationLines]);       });         </script>     </head>         <body>         <!-- application will go here -->         <div id="mapView" data-dojo-type="dojox.mobile.View" data-dojo-props="selected: true">             <div id="header" data-dojo-type="dojox.mobile.Heading">                 <div id="aboutButton" data-dojo-type="dojox.mobile.ToolBarButton" style="float: right;"                 moveTo="aboutView">                     About                 </div>                 <div id="legendButton" data-dojo-type="dojox.mobile.ToolBarButton" style="float: right;"                 moveTo="legendView">                     Legend                 </div>             </div>             <div id="mapContainer" data-dojo-type="dojox.mobile.ContentPane">                 <div id="map">                 </div>             </div>         </div>         <div id="aboutView" data-dojo-type="dojox.mobile.View">             <h1 data-dojo-type="dojox.mobile.Heading" data-dojo-props="back:'Map', moveTo:'mapView'">                 About             </h1>             <p style="padding: 5px;">                 Community College District             </p>             <div id="testtext">             </div>             <p>                 Web mapping application of campus utilities and infrastructure.             </p>         </div>         <div id="legendView" data-dojo-type="dojox.mobile.View">             <h1 data-dojo-type="dojox.mobile.Heading" data-dojo-props="back:'Map', moveTo:'mapView'">                 Legend             </h1>                   <div data-dojo-type="dojox.mobile.ContentPane" id="legendPane" data-dojo-props="title:'Legend', selected:true">                 <div id="legendDiv">                 </div>             </div>         </div>     </body>   </html>
KellyHutchins
Esri Notable Contributor
The reason the popup isn't appearing on the mobile device may be due to a dojo bug. The response from Derek in this post has details on how to fix the issue:
http://forums.arcgis.com/threads/94963-Javascript-API-map-3.7-has-no-coordinates-when-handling-map-c...
There were a few issues with your code that were causing issues with displaying the popup. Try this code instead:
        var popupTemplate = new esri.InfoTemplate("${STATE_NAME}", "${SUB_REGION}");            var IrrigationLines = new esri.layers.FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3", {             mode: esri.layers.FeatureLayer.MODE_ONDEMAND,             infoTemplate: popupTemplate,             outFields: ["*"]         });
The main issue is that you were using PopupTemplate syntax with an InfoTemplate. I don't think the documentation does a good job of explaining that there are two template types and you can use either with a Popup or InfoWindow. We'll work on clarifying the doc for a future release. In the example above I switched to the InfoTemplate and specified that the title use content from the state name field and the description information from the sub region field.
KellyHutchins
RickHendrickson
Wow, thanks! Those two fixes worked. Still a little confused about the infotemplate but eventually I'll figure it out...with a little help from the forum.
Rick
