Mixing AMD and non-AMD widgets?
1868
05-06-2013 01:11 PM
KenBuja
MVP Esteemed Contributor
When using AMD code, is it possible to use the older widgets that were written in the legacy code (using dojo.provide, dojo.require, and dojo.declare)? Or do the widgets also need to be updated to AMD?
If it is possible to use the older widgets, what would the code look like?
VivekPrasad
Yes, it is possible.
VivekPrasad
KenBuja
I'm using nliu's TOC widget and it's not working when I use AMD. Here's the original code that works:
   <script type="text/javascript">
        dojo.require("agsjs.dijit.TOC");
        dojo.require("esri.arcgis.utils");
        dojo.require("esri.dijit.BasemapGallery");
        //dojo.require("esri.dijit.Popup");
        dojo.require("esri.map");
        dojo.require("dojo.data.ItemFileReadStore");
        //dojo.require("dijit.layout.AccordionContainer");
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        dojo.require("dijit.layout.TabContainer");
        dojo.require("dijit.TitlePane");
        dojo.require("dojo.fx"); // needed if use jsapi 3.0
        dojo.require("dojox.grid.DataGrid");
    </script>
        var map;
        var identifyTask, identifyParams;
        var urlSEFCRI = "http://myserver/ArcGIS/rest/services/biogeo/SEFCRI/MapServer"
        var layerSEFCRI;
        var tasks;
        var clickPoint;
        function init() {
            var popup = new esri.dijit.Popup({
                fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]))
            }, dojo.create("div"));
            map = new esri.Map("map", {
                basemap: "oceans",
                showAttribution: false,
                logo: false,
                infoWindow: popup,
                center: [-80.2, 26.67],
                zoom: 11
            loading = dojo.byId("loadingImg");
            layerSEFCRI = new esri.layers.ArcGISDynamicMapServiceLayer(urlSEFCRI, {
            map.addLayers([layerSEFCRI]); // Suba's edit
            dojo.connect(map, 'onLayersAddResult', function (results) {
                var toc = new agsjs.dijit.TOC({
                    map: map,
                    layerInfos: [{
                        layer: layerSEFCRI,
                        title: "SEFCRI",
                        slider: true
                }, 'tocDiv');
                toc.startup();
                layerSEFCRI.setVisibleLayers([0]);
                mapReady(map);
</script>
This AMD version doesn't work.
var map;
var urlSEFCRI = "http://myserver/ArcGIS/rest/services/biogeo/SEFCRI/MapServer";
var layerSEFCRI;
require([
    "agsjs/dijit/TOC",
    "dojo/_base/connect",
    "dojo/parser",
    "dojo/ready",
    "esri/map",
    "esri/InfoTemplate",
    "esri/arcgis/utils",
    "esri/dijit/InfoWindow",
    "dijit/layout/BorderContainer",
    "dijit/layout/ContentPane",
    "dojo/domReady!"
], function (
        TOC,
        connect, parser, ready,
        Map, InfoTemplate,
        InfoWindow) {
    ready(function () {
        //parser.parse();
    map = new Map("map", {
        basemap: "oceans",
        logo: false,
        //infoWindow: popup,
        zoom: 11
    map.resize();
    connect.connect(map, "onLayerAddResult", function (results) {
        var toc = new TOC({
            map: map,
            layerInfos: [{
                layer: layerSEFCRI,
                title: "SEFCRI",
                slider: true
        }, 'tocDiv');
        toc.startup();
        console.log("loaded");
        mapReady(map);
If I comment out the code in red, the map works as expected (and shows the "loaded" log).
KenBuja
This code works properly
<!DOCTYPE html>
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title>TOC</title>
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css">
    <style>
        html, body
            height: 100%;
            width: 100%;
            margin: 0;
            padding: 0px;
            font-family: helvetica, arial, sans-serif;
            font-size: 90%;
        #leftPane
            width: 280px;
            overflow: auto;
        /* this line hide layers when out of scale for the inline TOC */
        #scaleDiv .agsTOCOutOfScale
            display: none;
    </style>
        var djConfig = {
            parseOnLoad: true,
            packages: [{
                "name": "agsjs",
                "location": location.pathname.replace(/\/[^/]+$/, "") + '/agsjs'
                //"location": 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.04/xbuild/agsjs' // for xdomain load
    </script>
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/"></script>
        var map;
        var urlSEFCRI = "http://egisws02.nos.noaa.gov/ArcGIS/rest/services/biogeo/SEFCRI/MapServer"
        require([
           "dojo/parser",
           "dojo/ready",
           "esri/map",
           "agsjs/dijit/TOC",
            "dojo/domReady!"
        ], function (
        Map) {
            ready(function () {
                //parser.parse();
                basemap: "oceans",
                logo: false,
                zoom: 11
            map.resize();
            connect.connect(map, 'onLayersAddResult', function (results) {
                    map: map,
                    layerInfos: [{
                        layer: layerSEFCRI,
                        title: "SEFCRI",
                        slider: true
                }, 'tocDiv');
                toc.startup();
                console.log("Set TOC");
            connect.connect(layerSEFCRI, "onLoad", function () {
                map.setExtent(layerSEFCRI.initialExtent, true);
            var resizeTimer;
            connect.connect(map, 'onLoad', function (theMap) {
                connect.connect(dijit.byId('map'), 'resize', function () { //resize the map if the div is resized
                    clearTimeout(resizeTimer);
                    resizeTimer = setTimeout(function () {
                        map.resize();
                        map.reposition();
                    }, 500);
            dojo.connect(layerSEFCRI, "onLoad", function () {
    </script>
</head>
<body class="claro">
    <div id="content" dojotype="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
        <div dojotype="dijit.layout.ContentPane" id="leftPane" region="left" splitter="true">
            <div id="tocDiv">
            </div>
        </div>
        <div id="map" dojotype="dijit.layout.ContentPane" region="center">
        </div>
    </div>
</body>
</html>
YgorThomaz
<!DOCTYPE html>
<head>
    <title>TOC</title>
    <style>
        html, body
            height: 100%;
            width: 100%;
            margin: 0;
            padding: 0px;
            font-size: 90%;
        #leftPane
            width: 280px;
            overflow: auto;
            display: none;
    </style>
        var djConfig = {
            parseOnLoad: true,
            packages: [{
                "name": "agsjs",
    </script>
        var map;
        require([
           "dojo/parser",
           "dojo/ready",
           "esri/map",
           "agsjs/dijit/TOC",
            "dojo/domReady!"
        ], function (
        Map) {
            ready(function () {
                //parser.parse();
                basemap: "oceans",
                logo: false,
                zoom: 11
            map.resize();
                    map: map,
                    layerInfos: [{
                        layer: layerSEFCRI,
                        title: "SEFCRI",
                        slider: true
                }, 'tocDiv');
                toc.startup();
            var resizeTimer;
                        map.resize();
                        map.reposition();
                    }, 500);
    </script>
</head>
            <div id="tocDiv">
            </div>
        </div>
        </div>
    </div>
</body>
</html>
It's works! Why can't we use the code below?
var toc = new TOC({
            map: map,
            layerInfos: [{
                layer: layerSEFCRI,
Thanks!
