Min/Max Zoom on view
9396
6
11-10-2017 04:10 PM
NachiChidambaram
I am trying to set the following properties on the view   (arcgis api 4.5)
effectiveMinZoom
effectiveMaxZoom.
So that I can set the max and min allowed zoom level .    For some reason I don't see any errors and the min and max zoom levels are not set.
I also tried minZoom and maxZoom. No luck
Here is my code :
var map = new Map({
            basemap: "hybrid"
           // map.add(transportationLyr);
        var view = new MapView({
            container: "viewDiv",  // Reference to the DOM node that will contain the view
            map: map,               // References the map object created in step 3
            zoom: 12,
            effectiveMaxZoom: 15,
            effectiveMinZoom: 10,
            center: [-82.78,35.0],
            padding:{
                right:320
NachiChidambaram
This worked for me
this.view.constraints = {
minZoom: 9
RobertScheitlin__GISP
Nachi,
  Looks like you need to be looking at view constraints. minScale and maxScale are properties of the constraints property of the MapView.
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#constraints
NachiChidambaram
This worked for me
minZoom: 9
Nachi,
   Glad to hear it. Don't forget to mark this question as answered by clicking the "Mark Correct" link on the reply that answered your question.
NachiChidambaram
Is it possible to show marker based on zoom level (something like as we zoom in more points are visible).
So that they are not overlapping when zoom out too far and looks clean on map view ?
GuillaumeSPRIET
par contre
GuillaumeSPRIET
ça fonctionne ap
