Migrating from 3.x to 4.x
4298
03-14-2023 01:18 PM
ChitraKrishnan
Our current application that uses Arcgis javascript API 3.x is built on dojo framework. Now we are planning to migrate to 4.x. Can we just insert the 4.x CDN link and continue with the dojo framework?
Thanks
Chitra
3 Solutions
SteveCole
Honored Contributor
No, unfortunately, app migration from 3.x to 4.x will be a more involved process than just updating the CDN path. ESRI has a page in its 4.x documentation that talks about migrating (link here). More than likely, you will have to end up rewriting good portions of your app.
KenBuja
MVP Esteemed Contributor
Also, the CDN no longer contains the Dojo framework packages. 4.x started moving away from them in version 4.14 and got rid of them completely by 4.18.
BlakeTerhune
I think plain, vanilla JavaScript is preferable, unless you have a specific need for functionality provided by a framework (like React, Vue, Angular, etc.).
SteveCole
Honored Contributor
KenBuja
ChitraKrishnan
Hi Steve, KenBuja,
Thanks for your response. I would like to know what would be the preferred language to rewrite the migration?
Thanks
Chitra
BlakeTerhune
