Message: '0.geometry' is null or not an object
1468
03-20-2013 01:59 AM
SaiDake
Hi, i get "Message: '0.geometry' is null or not an object" javascript error when i try to render the map in IE. It works fine in mozilla.
plotAddressId= function plotAddressId(addressId, state, attributes) {
          // alert(attributes);
            addressIdQuery = new esri.tasks.Query();
            addressIdQuery.returnGeometry = true;
            addressIdQuery.where = "ADDRESS_KEY = '" + state + addressId + "'";
            addressIdQueryTask.execute(addressIdQuery, function(results) {
              var geom = results.features[0].geometry;
              var graphic = new esri.Graphic(geom, locationSymbol);
              graphic.setAttributes(attributes);
              locationGraphicsLayer.add(graphic);
              zoomToLocations();
This piece of code is generating it. However, when i uncomment the alert message, i dnt see the script error. Its basically waitings for somethings to load prior to it. What is the work around for this?
JasonScharf
Are you using AMD modules in your code?
I've seen dojo's AMD loader do this in IE when you include an AMD module with a script tag, instead of with require.
Bad:
<script src="myModule.js"></script>
Good:
<script type="text/javascript">
    require("myModule.js");
</script>
SaiDake
Thx for replying!! No, im not using.
