Measurement Widget
918
02-21-2013 12:34 PM
JanetReynolds
The measurement widget isn't displaying the correct results.  I'm using javascript 3.1 api and 9.3.1 server.   Do you think it is because I'm using 9.3.1 server or a projection problem?  My wkid is 32100.
Any advice or suggestion would be appreciated.
RahulMetangale1
jreynolds,
it is not related to the version of ArcGIS Server. Against what are you comparing the results return by measurement tool? Following blog might help in this situation:
http://blogs.esri.com/esri/arcgis/2010/03/05/measuring-distances-and-areas-when-your-map-uses-the-me...
