measurement widget
1857
04-13-2017 08:08 AM
VenkatM2
Hi
In Measurement Widget, 'measure-end' event is fired when you switch units in location tool, causing populating location results either in DMS or Degree's even though there is no feature(point) present in the Map.
Steps to replicate the scene.
1. Open the Measurement Widget and switch to Location tool.
2. Select one of the Unit system and try click on a Map adds an point feature on the Map, produces location result based on the Unit system selected at the results span.
3. Then deactivate the tool by clicking the tool again. Then the feature added previously is cleared at the same time result also cleared from results span.
4. Then again activate the tool by clicking the tool again and try change the Units from currently selected to different one.
5. Now you can see an result is populated in results span without clicking on the Map. We don't see a feature on the Map but an result is populated in span.
Can anybody guide me to avoid this unnecessary populating results in the results span.
Thank you.
Venkat.
KellyHutchins
Esri Notable Contributor
This is due to a bug in the Measurement widget where the internal memory isn't being cleared out. We'll get it fixed in a future release.
VenkatM2
Hi Kelly,
Thanks for the reply. When I can expect the next release on this widget.
Thanks.
-Venkat.
KellyHutchins
Look for it in early July around the time of the Esri User Conference.
