Measurement Widget Problem
1670
04-08-2014 07:12 PM
JamesFan
In Measurement Tool sample page (http://developers.arcgis.com/javascript/samples/widget_measurement/)
I can't measure "distance" in Measurement Widget when using Chrome/Firefox/IE, but "Area" and "Pin" is Okay.
Did anybody have the same problem.. Thanks.
James Fan
JeffPace
working fine in chrome 33 for me
RyanSmith1
Hi Jeff, i have a issue with IE 10 regarding the Measure widget. Kindly check the following post, Measure Widget issue on IE 10
Ryan
JonathanUihlein
Ryan, the version you are using came out in March 2013, and the first stable release of IE10 came a month before that.
You may want to try upgrading to a newer version of the API.
