Measurement widget digits
854
11-05-2012 02:34 PM
DavidAglietti
Does anyone know if it is possible to control the number of digits to the right of the decimal in the measurement widget results?
Ryan
JanJeske
For this i think you have to modify your measurement.js in the jsapi.
in thi js search the function _outputResult: inside of this are 2 functions:
.toPrecision(X) for values > 1000000 //default is 9
.toFixed(X) >0 < 1000000 //default is 2
modify X will change the numbers of digits on the right
also you can add variables so that you can change the precision dynamicly from your application
