Measurement tool
4036
11
09-10-2014 07:39 AM
KeisukeNozaki
I am trying to add measurement tool to my existing code.
What I did was:
1. add "esri/dijit/Measurement" and variable
2. add the following code after loading feature layer
        //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac., but has wrong code for Chrome on Mac
        var snapManager = map.enableSnapping({
          snapKey: has("mac") ? keys.META : keys.CTRL
        var layerInfos = [{
          layer: parcelsLayer
        snapManager.setLayerInfos(layerInfos);
        var measurement = new Measurement({
          map: map
        }, dom.byId("measurementDiv"));
        measurement.startup();
3. add <div id="measurementDiv"></div> in the end
However, the measurement tool does not display.
Please let know what is missing.
Thank you.
Keisuke
Tags (1)
TimWitt2
I had to comment out line 133 to 140.
Added "dijit/TitlePane" to line 74.
Added the lines between 257 and 262.
TimWitt2
Keisuke,
did you add "dojo/parser" and variable? Then add parser.parse();
Maybe looking at this example can help? Measurement | ArcGIS API for JavaScript
Tim
KeisukeNozaki
Yes, I did.  Here is a code.
Thank you.
Keisuke
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>MCD Mobile GIS</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
    <style>
      html, body {
        height: 100%; width: 100%;
        margin: 0; padding: 0;
      #map{
        padding:0;
        border:solid 1px #343642;
        margin:5px 5px 5px 5px;
        #LocateButton {
      position: absolute;
      top: 95px;
      left: 20px;
      z-index: 50;
            #top{
        width:20%;
        border-top: solid 1px #343642;
        border-left: solid 1px #343642;
        border-bottom: solid 1px #343642;
                border-right: solid 1px #343642;
        color: #343642;
        font:90% Arial,"Arial",Arial,Arial;
        /*letter-spacing: 0.05em;*/
     </style>
<script>
  (function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i=i||function(){
  (i.q=i.q||[]).push(arguments)},i.l=1*new Date();a=s.createElement(o),
  m=s.getElementsByTagName(o)[0];a.async=1;a.src=g;m.parentNode.insertBefore(a,m)
  })(window,document,'script','//www.google-analytics.com/analytics.js','ga');
  ga('create', 'UA-21888440-1', 'wiu.edu');
  ga('send', 'pageview');
</script>
    <script src="http://js.arcgis.com/3.8/"></script>
    <script>
      var map, locator;
      require([
        "esri/map", "esri/tasks/locator", "esri/graphic",
        "esri/dijit/InfoWindowLite", "esri/InfoTemplate", "esri/layers/FeatureLayer", "dojo/dom-construct",
        "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/Font", "esri/symbols/TextSymbol",
        "dojo/_base/array", "dojo/_base/Color",
        "dojo/number", "dojo/parser", "dojo/dom", "dojo/on", "dijit/registry",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/ArcGISTiledMapServiceLayer",
                "esri/dijit/LocateButton",
                "esri/dijit/Scalebar",
                "esri/dijit/Measurement",
        "dijit/form/Button", "dijit/form/Textarea",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Map, Locator, Graphic,
        InfoWindowLite, InfoTemplate, FeatureLayer, domConstruct,
        InfoTemplate, SimpleMarkerSymbol,
        Font, TextSymbol,
        arrayUtils, Color,
        number, parser, dom, on, registry,
        ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, LocateButton, Scalebar, Measurement
        parser.parse();
        var initExtent = new esri.geometry.Extent({"xmin":-10093755,"ymin":4932648,"xmax":-10093139,"ymax":4933004,"spatialReference":{"wkid":3857}});
        var map = new esri.Map("map",{extent:initExtent});
        var basemap2 = new ArcGISTiledMapServiceLayer("http://gis.wiu.edu/arcgis/rest/services/basemap/aerial_cache/MapServer",
                {"opacity" : 0.6});
        map.addLayer(basemap2);
        var basemap = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.wiu.edu/arcgis/rest/services/mcdonough_mobile/MapServer");
        map.addLayer(basemap);
                geoLocate = new LocateButton({
        map: map,
                scale: 2400,
                tracking: true,
                useTracking: true
                }, "LocateButton");
                geoLocate.startup();
                var scalebar = new Scalebar({
          map: map,
          // "dual" displays both miles and kilmometers
          // "english" is the default, which displays miles
          // use "metric" for kilometers
          scalebarUnit: "dual"
    /*var infoWindow = new InfoWindowLite(null, domConstruct.create("div", null, null, map.root));
    infoWindow.startup();
    map.setInfoWindow(infoWindow);*/
    var template = new InfoTemplate();
    template.setTitle("<b>${PARCELID}</b>");
    template.setContent("${owner1_name} <br> ${site_address} <br> <a href =${wedge_url} target='_blank'>PRC Link</a>");
    //add a layer to the map
    var featureLayer = new FeatureLayer("http://gis.wiu.edu/arcgis/rest/services/mcdonough_highway/MapServer/21", {
                mode: FeatureLayer.MODE_ONDEMAND,
                maxAllowableOffset: 1000,
        infoTemplate:template,
        outFields: ["PARCELID" , "site_address", "owner1_name", "wedge_url"]
    map.addLayer(featureLayer);
    map.infoWindow.resize(200, 75);
        var layerInfos = [{
          layer: parcelsLayer
          map: map
   on(dom.byId("address"), "keyup", function(event){
       if (event.keyCode == 13 && this.value.length > 0) {
                locate();
        locator = new Locator("http://gis.wiu.edu/arcgis/rest/services/mcdonough_structure/GeocodeServer");
        locator.on("address-to-locations-complete", showResults);
        // listen for button click then geocode
        map.infoWindow.resize(200,125);
        on(dom.byId("address"), 'onkeyup', function(event) {
                locate();
        function locate() {
          map.graphics.clear();
          var address = {
            "Street": dom.byId("address").value
          locator.outSpatialReference = map.spatialReference;
          var options = {
            address: address,
            outFields: ["HouseNum"]
          locator.addressToLocations(options);
        function showResults(evt) {
          var candidate;
          var symbol = new SimpleMarkerSymbol();
          var infoTemplate = new InfoTemplate(
            "Location",
            "Address: ${address}<br />Score: ${score}<br />Source locator: ${locatorName}"
          symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
          symbol.setSize(10);
          symbol.setColor(new Color("#ffff00"));
          var geom;
          arrayUtils.every(evt.addresses, function(candidate) {
            console.log(candidate.score);
            if (candidate.score > 80) {
              console.log(candidate.location);
              var attributes = {
                address: candidate.address,
                score: candidate.score,
                locatorName: candidate.attributes.StreetName
              geom = candidate.location;
              var graphic = new Graphic(geom, symbol, attributes, infoTemplate);
              //add a graphic to the map at the geocoded location
              map.graphics.add(graphic);
              //add a text symbol to the map listing the location of the matched address.
              var displayText = candidate.address;
              var font = new Font(
                "12pt",
                Font.STYLE_NORMAL,
                Font.VARIANT_NORMAL,
                Font.WEIGHT_BOLD,
                "Helvetica"
              var textSymbol = new TextSymbol(
                displayText,
                font,
              textSymbol.setOffset(0,15);
              map.graphics.add(new Graphic(geom, textSymbol));
              return false; //break out of loop after one candidate with score greater  than 80 is found.
            else{
            alert("No results found, please enter another address");
          if ( geom !== undefined ) {
            map.centerAndZoom(geom, 19);
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'sidebar', gutters:false"
         style="width:100%; height:100%;">
        <div id="top"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'top'">
        <font size = "3">MCD Mobile</font> <br>
                <font size = "2">WIU GIS Center  <a href="help.html"><b>Help</b></a></font> <br>
        <input type="text" id="address" size="25" autofocus="autofocus"/>
        <br>
      </div>
            <div id="map"
           data-dojo-props="region:'center'">
            <div id="LocateButton"></div>
            </div>
    </div>
  </body>
</html>
TimWitt2
Keisuke,
the issue is you don't put your measurement widget into a Title Pane like in the example. You only put it in the map but there is nothing to house it.
Tim
TimWitt2
This code works:
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      html, body {
      #map{
        padding:0;
      #titlePane{
        width:240px;
        #LocateButton {
      position: absolute;
      top: 95px;
      left: 20px;
      z-index: 50;
            #top{
        width:20%;
        color: #343642;
     </style>
<script>
</script>
    <script>
      var map, locator;
      require([
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane","dijit/TitlePane", "dojo/domReady!"
      ], function(
        Font, TextSymbol,
        arrayUtils, Color,
        parser.parse();
        var map = new Map("map",{extent:initExtent});
                {"opacity" : 0.6});
        map: map,
                scale: 2400,
                tracking: true,
                useTracking: true
                }, "LocateButton");
          map: map,
       // var snapManager = map.enableSnapping({
          //snapKey: has("mac") ? keys.META : keys.CTRL
        //var layerInfos = [{
        //  layer: parcelsLayer
        //snapManager.setLayerInfos(layerInfos);
          map: map
                locate();
                locate();
        function locate() {
          var address = {
          var options = {
            address: address,
          var candidate;
            "Location",
          symbol.setSize(10);
          var geom;
              var attributes = {
                "12pt",
                Font.STYLE_NORMAL,
                Font.WEIGHT_BOLD,
                "Helvetica"
                displayText,
                font,
            else{
    </script>
  </head>
        <div id="top"
        <br>
      </div>
            <div id="map"
    <div style="position:absolute; right:20px; top:10px; z-Index:999;">
              <div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
            <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
          </div>
          </div>
   </div>
    </div>
  </body>
</html>
KeisukeNozaki
Yes, it works.
Would you please tell me which part you changed?
I added "dijit/TitlePane" and the line from 257 to 262.
Thank you.
TimWitt2
KeisukeNozaki
Thank you so much, Tim.
TimWitt2
No problem!
KeisukeNozaki
Tim,
The code works great.
But I noticed I am not able to draw line or polygon for measurement tool due to popups.
Any workaround?
Keisuke
