Measurement tool
4029
11
09-10-2014 07:39 AM
KeisukeNozaki
I am trying to add measurement tool to my existing code.
What I did was:
1. add "esri/dijit/Measurement" and variable
2. add the following code after loading feature layer
        //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac., but has wrong code for Chrome on Mac
        var snapManager = map.enableSnapping({
          snapKey: has("mac") ? keys.META : keys.CTRL
        var layerInfos = [{
          layer: parcelsLayer
        snapManager.setLayerInfos(layerInfos);
        var measurement = new Measurement({
          map: map
        }, dom.byId("measurementDiv"));
        measurement.startup();
3. add <div id="measurementDiv"></div> in the end
However, the measurement tool does not display.
Please let know what is missing.
Thank you.
Keisuke
Tags (1)
TimWitt2
I'll take a look tomorrow.
TimWitt2
I had to upgrade you to 3.10.
I had to stop your tracking on line 100 and 101.
I removed your legacy code, now your application is AMD.
I added lines 234 to 246.
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>MCD Mobile GIS</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
    <style>
      html, body {
        height: 100%; width: 100%;
        margin: 0; padding: 0;
      #map{
        padding:0;
        border:solid 1px #343642;
        margin:5px 5px 5px 5px;
      #titlePane{
        width:240px;
        #LocateButton {
      position: absolute;
      top: 95px;
      left: 20px;
      z-index: 50;
            #top{
        width:20%;
        border-top: solid 1px #343642;
        border-left: solid 1px #343642;
        border-bottom: solid 1px #343642;
                border-right: solid 1px #343642;
        color: #343642;
        font:90% Arial,"Arial",Arial,Arial;
        /*letter-spacing: 0.05em;*/
    </style>
<script>
  (function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i=i||function(){
  (i.q=i.q||[]).push(arguments)},i.l=1*new Date();a=s.createElement(o),
  m=s.getElementsByTagName(o)[0];a.async=1;a.src=g;m.parentNode.insertBefore(a,m)
  })(window,document,'script','//www.google-analytics.com/analytics.js','ga');
  ga('create', 'UA-21888440-1', 'wiu.edu');
  ga('send', 'pageview');
</script>
    <script src="http://js.arcgis.com/3.10/"></script>
    <script>
      var map, locator;
      require([
        "esri/map", "esri/tasks/locator", "esri/graphic",
        "esri/dijit/InfoWindowLite", "esri/InfoTemplate", "esri/layers/FeatureLayer", "dojo/dom-construct",
        "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/Font", "esri/symbols/TextSymbol",
        "dojo/_base/array", "dojo/_base/Color",
        "dojo/number", "dojo/parser", "dojo/dom", "dojo/on", "dijit/registry",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/ArcGISTiledMapServiceLayer",
                "esri/dijit/LocateButton",
                "esri/dijit/Scalebar",
                "esri/dijit/Measurement",  "esri/geometry/Extent",
        "dijit/form/Button", "dijit/form/Textarea",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane","dijit/TitlePane", "dojo/domReady!"
      ], function(
        Map, Locator, Graphic,
        InfoWindowLite, InfoTemplate, FeatureLayer, domConstruct,
        InfoTemplate, SimpleMarkerSymbol,
        Font, TextSymbol,
        arrayUtils, Color,
        number, parser, dom, on, registry,
        ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, LocateButton, Scalebar, Measurement, Extent
        parser.parse();
        var initExtent = new Extent({"xmin":-10093755,"ymin":4932648,"xmax":-10093139,"ymax":4933004,"spatialReference":{"wkid":3857}});
        var map = new Map("map",{extent:initExtent});
        var basemap2 = new ArcGISTiledMapServiceLayer("http://gis.wiu.edu/arcgis/rest/services/basemap/aerial_cache/MapServer",
                {"opacity" : 0.6});
        map.addLayer(basemap2);
        var basemap = new ArcGISDynamicMapServiceLayer("http://gis.wiu.edu/arcgis/rest/services/mcdonough_mobile/MapServer");
        map.addLayer(basemap);
                geoLocate = new LocateButton({
        map: map,
                scale: 2400,
                //tracking: true,
                //useTracking: true
                }, "LocateButton");
                geoLocate.startup();
                var scalebar = new Scalebar({
          map: map,
          // "dual" displays both miles and kilmometers
          // "english" is the default, which displays miles
          // use "metric" for kilometers
          scalebarUnit: "dual"
    /*var infoWindow = new InfoWindowLite(null, domConstruct.create("div", null, null, map.root));
    infoWindow.startup();
    map.setInfoWindow(infoWindow);*/
    var template = new InfoTemplate();
    template.setTitle("<b>${PARCELID}</b>");
    template.setContent("${owner1_name} <br> ${site_address} <br> <a href =${wedge_url} target='_blank'>PRC Link</a>");
    //add a layer to the map
    var featureLayer = new FeatureLayer("http://gis.wiu.edu/arcgis/rest/services/mcdonough_highway/MapServer/21", {
                mode: FeatureLayer.MODE_ONDEMAND,
                maxAllowableOffset: 1000,
        infoTemplate:template,
        outFields: ["PARCELID" , "site_address", "owner1_name", "wedge_url"]
    map.addLayer(featureLayer);
    map.infoWindow.resize(200, 75);
      // var snapManager = map.enableSnapping({
          //snapKey: has("mac") ? keys.META : keys.CTRL
        //var layerInfos = [{
        //  layer: parcelsLayer
        //snapManager.setLayerInfos(layerInfos);
          map: map
  on(dom.byId("address"), "keyup", function(event){
      if (event.keyCode == 13 && this.value.length > 0) {
                locate();
        locator = new Locator("http://gis.wiu.edu/arcgis/rest/services/mcdonough_structure/GeocodeServer");
        locator.on("address-to-locations-complete", showResults);
        // listen for button click then geocode
        map.infoWindow.resize(200,125);
        on(dom.byId("address"), 'onkeyup', function(event) {
                locate();
        function locate() {
          map.graphics.clear();
          var address = {
            "Street": dom.byId("address").value
          locator.outSpatialReference = map.spatialReference;
          var options = {
            address: address,
            outFields: ["HouseNum"]
          locator.addressToLocations(options);
        function showResults(evt) {
          var candidate;
          var symbol = new SimpleMarkerSymbol();
          var infoTemplate = new InfoTemplate(
            "Location",
            "Address: ${address}<br />Score: ${score}<br />Source locator: ${locatorName}"
          symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
          symbol.setSize(10);
          symbol.setColor(new Color("#ffff00"));
          var geom;
          arrayUtils.every(evt.addresses, function(candidate) {
            console.log(candidate.score);
            if (candidate.score > 80) {
              console.log(candidate.location);
              var attributes = {
                address: candidate.address,
                score: candidate.score,
                locatorName: candidate.attributes.StreetName
              geom = candidate.location;
              var graphic = new Graphic(geom, symbol, attributes, infoTemplate);
              //add a graphic to the map at the geocoded location
              map.graphics.add(graphic);
              //add a text symbol to the map listing the location of the matched address.
              var displayText = candidate.address;
              var font = new Font(
                "12pt",
                Font.STYLE_NORMAL,
                Font.VARIANT_NORMAL,
                Font.WEIGHT_BOLD,
                "Helvetica"
              var textSymbol = new TextSymbol(
                displayText,
                font,
              textSymbol.setOffset(0,15);
              map.graphics.add(new Graphic(geom, textSymbol));
              return false; //break out of loop after one candidate with score greater  than 80 is found.
            else{
            alert("No results found, please enter another address");
          if ( geom !== undefined ) {
            map.centerAndZoom(geom, 19);
  map.on("mouse-over", windowPop);
  function windowPop(){
  if (measurement.area.checked || measurement.distance.checked || measurement.location.checked){
  map.setInfoWindowOnClick(false);
  } else {
  map.setInfoWindowOnClick(true);
  measurement.on("measure-end", function (){
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer"
        data-dojo-props="design:'sidebar', gutters:false"
        style="width:100%; height:100%;">
        <div id="top"
          data-dojo-type="dijit/layout/ContentPane"
          data-dojo-props="region:'top'">
        <font size = "3">MCD Mobile</font> <br>
                <font size = "2">WIU GIS Center  <a href="help.html"><b>Help</b></a></font> <br>
        <input type="text" id="address" size="25" autofocus="autofocus"/>
        <br>
      </div>
            <div id="map"
          data-dojo-props="region:'center'">
    <div id="LocateButton"></div>
    <div style="position:absolute; right:20px; top:10px; z-Index:999;">
              <div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
            <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
          </div>
          </div>
  </div>
    </div>
  </body>
</html>
