Measurement dijit: How can I get more decimals after the point?
3575
12-04-2015 09:05 AM
YohanBienvenue1
The Measurement dijit always displays a specific number of decimals for each unit, e.g. 1 decimal for meters, 2 decimals for kilometers, etc.. I can't figure out how to have more decimals displayed. I know from stepping into the Measurement dijit code that the measure has plenty of decimals, however they all get truncated at some point before being displayed.
Yohan
KristianEkenes
The plan is to allow you as a developer to configure the decimal precision as a property on this widget in the 4.0 API.
RobertScheitlin__GISP
Yohan,
   Unfortunately I do not see any ability to configure the Measurement dijits result precision.
KristianEkenes
YohanBienvenue1
Ok thank you for this answer. I will stop searching
When doing property measurements two decimals is used 99% of the time, so we will change this when we switch to the 4.0 API.
