Measurement capabilities
3325
07-11-2014 01:02 AM
maximcouton
I am trying doing some developements using the ArcGis APi for JavaScript versin 3.9.
I wan to developpe a measurement tool but without using the Measurement Class
var measurement = new Measurement({
              map: map
}, dom.byId("measurementDiv"));
The above code creates a measurement widget with a coordinates, distance an a measurement area.
So I am wondering  if t is possible to developpe a measurement tool without using the Measurement class ?
DonOpgenorth
I've moved your post into the Web Developers space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. I have also added in a few additional tags. You can see more on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
