measure tool localization
6965
17
03-13-2012 05:52 AM
MatejSkerjanc
As per title, is it possible to localize the measure tool?
JohnGrayson
Esri Alum
The language local will be picked up from the browser settings. One way to force language localizations is to set the locale in dojoConfig.  Find the following tag in your html file and modify accordingly:
<script type="text/javascript">   var dojoConfig = {      parseOnLoad:true,      locale:"es"   }; </script>
More details in the JS API Localization concepts page.
Additionally, you can explicitly override and/or change the measure tool messages as described in the ArcGIS JavaScript API Dijit Text Strings help topic.
JianHuang
Yes. Similar to all JS widgets, measurement widget support 9 different languages. You just need to specify the locale in your config settings.
MatejSkerjanc
would you by any chance have any example of this? all i see in the template.js for localization is measure: { title:"sometihing", label: "somelabel"} what i want to localize are those combo box with measurement units and the messages
JohnGrayson
Esri Alum
MatejSkerjanc
oh thank you sir, i'll go read on it. Couldn't find anything via google or forum search yet, i bet your links will help.
update 1: tested the locale set it to SL and i get error Bundle not found: jsapi in esri , locale=SL. So i'll go read on it and report back when its done
update 2: upon reading the links i've solved it, just the DEGREES DMS remains to be solved since i cannot find it in the DIJIT text strings settings.
JianHuang
What language are you setting to?
MatejSkerjanc
I'm setting it to slovene.
__Rich_
hi all
can you  set the language of the measure tool to Hebrew?
From above - http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/localization.htm
__Rich_
sorry but
i didn't see Hebrew listed there !
am i missing something?
That was the point of the link - it's not listed i.e. not supported out of the box.
But note the page states:
You can define strings for additional locales by creating a new resource bundle file that contains the translated strings. View the Dojo help topic Globalization Guidelines: Locale and Resource Bundle for more details.
In other words, if you supply the translations then you can add support for additional languages.
Have you followed the guidelines and created your own bundle yet?  (I don't know of any samples for this, perhaps another forum member has done it?)
AdrianMarsden
Honored Contributor
Like lots of things, the measure widget is so close to being good, but needs a few tweaks.  For example changing the list of units for area and length, as well as being able to set a default for the point location tool (as well as changing the list of units) - for example no-one in our organization use long/lat or DMS we use British National Grid - all our data are defined in it and that is the only system we use.
Cheers
ACM
PS Does anyone else have the measure tool suddenly zoom in to almost real world scales on click?  You click and the map zooms into a VERy small area - so small the scale bar breaks with NaN for instead of numbers.??
