Map Won't Load in Chrome
4276
05-30-2018 08:40 AM
JohnMax
I can't get a map to load in Chrome.  Works well in IE and Safari and intermittently in Mozilla (must reload several times).  Console errors are attached.  Here's the webpage: https://www.washco.utah.gov/forms/emergency-services/fireworks-restrictions/
Any ideas?  Thanks!
KellyHutchins
Esri Notable Contributor
Seems like its because you are loading jquery after the Esri JSAPI. If you move the code that creates the map and loads the Esri JSAPI below the script tags that load jQuery it should be fine. Here's a stack overflow thread with a bit of detail:
javascript - Error Multiple Define when loading base script - Geographic Information Systems Stack E...
KellyHutchins
