Map | The popup is not displayed on the correct position
751
01-25-2023 08:13 AM
RoelGarcia
Hello All,
Currently I am investigating a popup issue, in some cases the popup is not displayed in the correct position, the Feature Layer handles the position of the popup (no UI code).
screenshot:
Esri's example:
Link: https://developers.arcgis.com/javascript/latest/sample-code/intro-popuptemplate/
I think this happens when we reduce the size of the map, especially the value of height.
I would appreciate any suggestion, thank you very much.
