map show no basemap just features
1056
12-10-2012 02:59 AM
MatejSkerjanc
How can i remove the basemap layer without it intefering with other features (i'm useing basemap gallery if that makes it any easier).
Maybe the sollution is to set it to null layer? Tried already but the following code doesnt work
dojo.forEach(basemapGallery.basemaps, function (basemap)
            menu.addChild(new dijit.MenuItem(
          label: basemap.title,
          iconClass: basemap.thumbnailUrl,
          onChange: function ()
          onClick: function (evt)
              if (basemap.id == 'blank')
                  basemapGallery.select(null);
                    else
                  basemapGallery.select(basemap.id);
Regards,
Matej
BillDaigle
I struggled with this same problem.  Eventually, I ended up creating an "empty" cached service on our server.  I say "empty" because I didn't actually create any of the tiles. Instead, I followed the instructions at the link below to include a single blank tile that gets displayed at all times:
http://support.esri.com/en/knowledgebase/techarticles/detail/36939
There may be a better solution, but this works me.
BillDaigle
MatejSkerjanc
thank you it is pretty much more logical then my current 20gb cache:)
