map setting width and height in inline style
3294
03-08-2013 01:04 AM
KierenHarvey
I have this scenario where an inline style is applied to the 'map' div setting the width and height to 400?
e.g. <div class="map" style="width: 400px; height: 400px"></div>
This is happening intermittently after new'ing up the esri map:
self.map = new esri.Map("map", {
                extent: self.gismapConfig.initialExtent,
                logo: true,
                infoWindow: popup,
                autoResize: true
What might cause this??
derekswingley1
If the element where a map is being created doesn't have a width and height, the API defaults to using 400 for both. This is defined in esri.config.defaults.map.height and esri.config.defaults.map.width.
To overcome this, specify a width and height on your element that will become a map (this could be an inline style, something in a style tag or in a .css file). See the create a map sample for an example that uses 100% for width and height:  http://help.arcgis.com/en/webapi/javascript/arcgis/samples/map_simple/index.html
KierenHarvey
The containing div had a width set (via a css style). I'm using bootstrap for layout.
It seemed that the DOM hadn't loaded when new'ing up the map. I rejigged where I'm wiring up the map and seems to have stopped applying the inline style, and filling the space defined by the parent div.
KierenHarvey
width & height config options aren't documented?
Closest I found was:
http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/#namespace_esri/config
http://help.arcgis.com/en/webapi/javascript/arcgis/jshelp/#inside_defaults
A link from the Map class doc would be nice 🙂
