map.setExtent not working
1730
01-26-2013 07:32 AM
NitinShinde
hi,
i m using arcgis js api 3.3 nd trying to zoom particular location by setting map extent. but it is not working.
var ext = new esri.geometry.Extent((parseFloat(arr.X) - 1000), (parseFloat(arr.Y) - 1000), (parseFloat(arr.X) + 1000), (parseFloat(arr.Y) + 1000), new esri.SpatialReference({wkid: 3414}));
map.setExtent(ext);
Udaya_BhaskerCheerala
Try using
var ext = new esri.geometry.Extent({"xmin":((parseFloat(arr.X)) - 1000, "ymin":(parseFloat(arr.Y) - 1000),"xmax": (parseFloat(arr.X) + 1000), "ymax":(parseFloat(arr.Y) + 1000), "spatialReference":{"wkid": 3414}});
map.setExtent(ext);
NitinShinde
Try using
map.setExtent(ext);
it is still not working...  😞
AmmarAssem1
Are you using this code without subtract
like this
var ext = new esri.geometry.Extent((parseFloat(arr.X)), (parseFloat(arr.Y)), (parseFloat(arr.X)), (parseFloat(arr.Y)), new esri.SpatialReference({wkid: 3414}));
map.setExtent(ext);
