Map popups don't respect MapView.ViewPadding
1783
06-21-2023 06:03 PM
JosephGrist
'padding' on a MapView does a great job of making Esri widgets avoid the obstructed area of the UI, and centering the zooming.  However,  popups do not respect the padding and still appear under the obscured area of the UI.
Is this a bug, or expected behaviour?  Wondering if there is a workaround that doesn't involve manipulating the DOM to position sidebars, etc. underneath the Esri popups....
UndralBatsukh
Hi there,
How are you setting the padding?
Please set the view.padding wholly: view.padding = { bottom: 400 }, not view.padding.bottom = 400. Doing so works as expected.  This codepen shows how to setting the padding wholly: https://codepen.io/U_B_U/pen/RwqGdmJ?editors=1000
We have an issue improve this down the road. Hope this helps,
UndralBatsukh
Hi there,
JosephGrist
Hi there.  Thanks, this is very helpful.  In this CodePen, the popup is behaving quite differently (and much better) to how it does in our solution. It looks like we have something in our environment that is interfering.  I will use this CodePen as a starting point for debugging what appears to be a fault run our code.  Thanks!
