map.on vs dojo/on
1417
05-12-2014 11:08 AM
CurtisSpurlock
map.on("load", doSomething);
on(map, "load", doSomething);
Is there a difference between the above statements.  I've seen both in the samples and I was curious.
ReneRubalcava
Esri Frequent Contributor
For just listening for events, no.
Map extends dojo/Evented, so that allows you to do use it like map.on() to listen for events. It also allows you to use dojo/on to listen for events on the map.
The added benefit of using dojo/on is it provides a little more utility, like pausable handlers.
var handler = on.pausable(map, 'click', method);
handler.pause();
// some other stuff happens
handler.resume();
Or you could listen to events only once.
on.once(map, 'load', method);
So it all depends on what you are looking to do. I would recommend using the dojo/on method, simply for consistency as you will probably use it to listen for other events as well.
CurtisSpurlock
Great!  Thanks for the information.
TracySchloss
Honored Contributor
I'm stuck with having to have my code work in IE 8, and I've had less problems with map.on syntax vs the on syntax.  I really wish we could get off it as our default browser, but for now we're stuck with it.  At least now they let users have something besides IE!
