Map.on key-down & key-up not working in IE 10?
1642
09-05-2013 08:39 AM
DominickCisson
I believe the map.on events "key-down" and key-up" are not functioning in Internet Exporter 10.  Has anyone else experienced this issue?
Below is a very simple modified ESRI sample that highlights this problem.  Run it in anything but IE 10 and the key-down event fires.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        background-color: #FFF;
        overflow: hidden;
        font-family: "Trebuchet MS";
    </style>
    <script src="http://js.arcgis.com/3.6/"></script>
    <script>
      var map;
      require(["esri/map", "dojo/domReady!"], function(Map) {
        map = new Map("map", {
          basemap: "topo",
          center: [-122.45,37.75], // long, lat
          zoom: 13,
          sliderStyle: "small"
        map.on("key-down",function(){console.log("Down!")});
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
ChrisJudd1
I can confirm this is still an issue on in the 3.7 version of the api and manifests itself on only with the key-up and key-down events but also in the tools that depend on key-up and key-down like snapping: https://developers.arcgis.com/en/javascript/jssamples/widget_measurement.html
Is there anything that folks are doing to get around this issue for IE 10?
ReneRubalcava
Honored Contributor
I haven't tried this with IE10 yet, but it worked in IE9, you might be able to do it like this.
// using the container div
map.container.onkeydown = function(e) {
 console.log("container: native listen down", e);
map.container.onkeyup = function(e) {
 console.log("container: native listen up", e);
// using the root div
map.root.onkeydown = function(e) {
 console.log("root: native listen down", e);
map.root.onkeyup = function(e) {
 console.log("root: native listen up", e);
However this is only works on the map in IE on my end, it didn't work in Chrome for me, so mileage may vary.
ChrisJudd1
Thanks, Rene, but unfortunately this did not work with IE 10...
