Map not reappearing after hide -> resize -> show
2479
05-03-2013 07:52 AM
MartinPritchard
I current having a problem with hiding and showing an esri Map.
The problem arises if the window is resized whilst the map is 'hidden'. If this happens, the map doesn't reappear when it should. I'm using CSS ('display:none') to hide the map.
If you don't 'resize' the window/map whilst the map is hidden, everything works as you'd expect.
I've put together a quick example of this behaviour here: http://jsfiddle.net/mart_blewpri/ZM3SM/
Any help would be much appreciated.
Cheers!
JeffJacobson
The same problem occurs with Esri's jQuery Mobile samples.
I haven't tested this myself yet, but someone posted this fix for this issue in jQuery Mobile.  Perhaps it will help with your problem as well.
http://forums.arcgis.com/threads/82287-Hiding-the-map-problems-with-building-a-mobile-application-wi...
MattLane
Yeah, you do have to work around the issue. Here is an example of how to do it with your sample http://jsfiddle.net/ZM3SM/5/
MartinPritchard
Thanks Matt.....Perfect!
