Map Not Displaying on Vue 2 with TypeScript and ES Modules
3533
6
08-04-2022 09:01 AM
MollyWhitener
I cannot get my map to display in my Vue 2 web app. I've done my best to follow the typing guide for ES Modules as well as the set up for TypeScript. I've tried some suggestions others have done, and those don't work either. The app compiles and runs and shows no errors. But the map does not display at all.
Does anyone have any idea what I'm doing wrong?
//tsconfig.json
  "compilerOptions": {
    "strict": true,
    "jsx": "preserve",
    "importHelpers": true,
    "moduleResolution": "node",
    "skipLibCheck": true,
    "esModuleInterop": true,
    "allowSyntheticDefaultImports": true,
    "sourceMap": true,
    "module": "ES2020",
    //"moduleResolution": "Node",
    "resolveJsonModule": true,
    "target": "ES2020",
    "baseUrl": ".",
    "types": [
      "webpack-env"
    "paths": {
        "src/*"
    "lib": [
      "esnext",
      "dom",
      "dom.iterable",
      "scripthost",
      "ES2020",
      "DOM"
  "include": [
    "./src",
    "src/**/*.ts",
    "src/**/*.tsx",
    "src/**/*.vue",
    "tests/**/*.ts",
    "tests/**/*.tsx"
  "exclude": [
    "node_modules"
//main.ts
import Vue from 'vue'
import App from './App.vue'
import router from './router'
import store from './store'
import vuetify from './plugins/vuetify'
import { ADLogin } from "@wwinc/NPM-VueADRedirect";
import { SecurityService } from './services/security-service';
import 'leaflet/dist/leaflet.css';
import { Icon } from 'leaflet';
import esriConfig from '@arcgis/core/config';
//esriConfig.assetsPath = 'https://js.arcgis.com/4.24/@arcgis/core/assets';
//esriConfig.assetsPath = './src/assets';
esriConfig.assetsPath = '../node_modules/@arcgis/core/assets';
esriConfig.apiKey = "APIKEY";
type D = Icon.Default & {
  _getIconUrl?: string;
delete (Icon.Default.prototype as D)._getIconUrl;
Icon.Default.mergeOptions({
  iconRetinaUrl: require('leaflet/dist/images/marker-icon-2x.png'),
  iconUrl: require('leaflet/dist/images/marker-icon.png'),
Vue.config.productionTip = false
console.log(`
Environment Settings:
  logonPageURL: ${process.env.VUE_APP_LOGINSITE_URL},
  logonApiURL: ${process.env.VUE_APP_LOGONAPI_URL},
  redirectURL: ${process.env.VUE_APP_LOGINREDIRECT_URI},
  baseURL: ${process.env.VUE_APP_BASE_URL},
  apiURL: ${process.env.VUE_APP_REP_API},
Vue.use(ADLogin, {
  router,
  logonPageURL: process.env.VUE_APP_LOGINSITE_URL,
  logonApiURL: process.env.VUE_APP_LOGONAPI_URL,
  redirectURL: process.env.VUE_APP_LOGINREDIRECT_URI,
  store,
  debug: false
new Vue({
  router,
  store,
  vuetify,
  render: h => h(App)
}).$mount('#app')
Vue.$security = new SecurityService();
Vue.prototype.$security = Vue.$security;
//main.css
@import "https://js.arcgis.com/4.24/@arcgis/core/assets/esri/themes/light/main.css";html,
body,
#app {
    font-family: Avenir, Helvetica, Arial, sans-serif;
    -webkit-font-smoothing: antialiased;
    -moz-osx-font-smoothing: grayscale;
    text-align: center;
    color: #2c3e50;
    padding: 0;
    margin: 0;
    width: 100%;
    height: 100%;
.mapdiv {
    padding: 0;
    margin: 0;
    height: 80vh;
//vue.config.js
let CopyPlugin;
CopyPlugin = require('copy-webpack-plugin');
module.exports = {
  publicPath: '/RepWrangler/',
  configureWebpack: {
    plugins: [
      new CopyPlugin([
        { from: 'web.config', to: './' },
    devtool: 'source-map'
  transpileDependencies: [
    'vuetify', '@arcgis/core'
  devServer: {
    disableHostCheck: true
//App.vue
<template>
  <v-app id="app">
    <v-app-bar
      app
      color="primary"
      absolute
        <v-img
          class="shrink ma-2"
          contain
          :src="require('../src/assets/cowboy.png')"
          transition="scale-transition"
          max-height="40"
          max-width="40"
      <v-toolbar-title>
        Rep Wrangler
      </v-toolbar-title>
      <v-spacer></v-spacer>
      <v-tooltip bottom>
        <template v-slot:activator="{on}">
          <v-btn icon v-on="on" @click="logout">
            <v-icon>mdi-logout</v-icon>
          </v-btn>
        </template>
        <span>Logout</span>
      </v-tooltip>
      <template v-slot:extension>
        <v-tabs align-with-title>
          <router-link
            style="display: flex"
            to="/">
            <v-tab style="color: white">Home</v-tab>
          </router-link>
          <router-link
            to="/map">
            <v-tab style="color: white">Retailers</v-tab>
          </router-link>
          <router-link
            to="/reptable">
            <v-tab style="color: white">Reps</v-tab>
          </router-link>
          <router-link
              to="/zipsearch">
            <v-tab style="color: white">Zip Search</v-tab>
          </router-link>
        </v-tabs>
      </template>
    </v-app-bar>
    <v-main>
      <router-view/>
    </v-main>
  </v-app>
</template>
<script lang="ts">
import Vue from 'vue';
export default Vue.extend({
  methods: {
    logout() {
      this.$logout();
  async beforeMount() {
    await this.$store.dispatch('JWT');
</script>
<style>
#app{
  background-color: var(--v-background-base) !important;
</style>
//MapComponent.vue
<template>
  <div class="mapdiv"></div>
</template>
<script lang="ts">
import Map from '@arcgis/core/Map';
import MapView from '@arcgis/core/views/MapView';
import FeatureLayer from '@arcgis/core/layers/FeatureLayer';
import esriConfig from "@arcgis/core/config";
    async mounted() {
        const apiKey = "APIKEY";
        const map = new Map({
          basemap: "arcgis-streets" // Basemap layer service
        const view = new MapView({
          map: map,
          center: [-92.0932, 38.232], // Longitude, latitude
          zoom: 5, // Zoom level
          container: 'mapdiv' // Div element
        const zipLabelClass = {
          labelExpressionInfo: {
            expression: "$feature.ZIP_CODE"
          labelPlacement: "above-center",
        const featureLayer = new FeatureLayer({
          apiKey: "APIKEY",
          url: "https://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/USA_Boundaries_2021/FeatureServer/3",
          opacity: 0.4,
        featureLayer.labelingInfo = [ zipLabelClass ];
        map.add(featureLayer);
</script>
<style scoped>
   @import '../main.css';
</style>
ReneRubalcava
Esri Frequent Contributor
Make these changes in your vue file. Your MapView was referencing the div className, and it had no id.
<div id="viewDiv" class="mapdiv"></div>
    map: map,
    container: "viewDiv",
    center: [-118.244, 34.052],
    zoom: 12
  You might also need to change the browserlist in the package.json. This is what we support.
  "browserslist": [
    "last 1 Chrome version",
    "last 1 Firefox version",
    "last 2 Edge major versions",
    "last 2 Safari major versions",
    "last 2 iOS major versions",
    "Firefox ESR"
Plus, I don't the assets are copied correctly in a production build, they should be in the public folder to get copied in a build, but if you don't use local assets, you don't need to worry about it.
ReneRubalcava
Can you break this down to simpler reproducible sample without routing, auth and environment variables in a github repo? Can't tell from what you've posted.
Only Vue2 app I have is this one, but it's a few years old and not sure it works anymore. It could be something in the dependencies or some other unknown.
https://github.com/odoe/jsapi-vue-template
MollyWhitener
Okay, I tried doing a very simple version as well, and it doesn't work here either.
https://github.com/mollyjw/ARCGis-Vue2
I guess I will just try to do Esri Leaflet instead of the JS API.
ReneRubalcava
Do you need to have the assets copied locally? Looks like something in the build is causing an issue there. You can remove the config.assetsPath part and load the assets from the CDN. Everything seems to work after that.
MollyWhitener
I tried it without copying the assets, and I just got a blank page. Are you seeing something?
ReneRubalcava
    map: map,
    zoom: 12
  "browserslist": [
    "Firefox ESR"
MollyWhitener
OH MY GOSH YOU'RE A GENIUS!
I didn't realize it had to be an id; I thought it was a class.
Thank you thank you so much!
