map loads in only half the div
3694
09-27-2012 07:45 AM
PramodHarithsa1
I have been trying to use two map objects at a time and got them working.
but mozilla doesn't help me out.
[ATTACH=CONFIG]18046[/ATTACH]
Here's how it loads it.
It works fine with IE and Chrome.
What am i missing?
Code is herein attached
A click on maximize button will reveal things 🙂
by Anonymous User
Not applicable
Original User: bgfield
Just messing around with your code, I tried removing the divs from line 191-195 and the advanced map opened full size in the new window.  Not sure if those divs will be necessary in your map later on, but hopefully it at least gives you an idea of where to start!
PramodHarithsa1
Not just that,
It works in IE and Chrome only on the machine its hosted.
Trying from somewhere else the div breaks.
I don't see an error. Can somebody guide me?
by Anonymous User
Not applicable
PramodHarithsa1
Thanks a lot brett.
That solved the problem.
Still wondering why i had them in place.
thanks again.
