map.load not failing when it probably should
1174
10-04-2016 12:28 PM
Martijnvan_de_Rijdt
I'm testing offline fallback funtcionality for an app that loads the init.js script locally. I'm trying to catch the error. This works fine if I initialize using a portalItem with a webMapID, but not if I use the following:
var webMapConfig = {
         basemap: "streets",
         ground: "world-elevation"
map = new WebMap( webMapConfig );
map.load()
   .otherwise( function( error ) {
       // THIS IS NOT REACHED
       console.error('map failed to load');
   .then(function(){
      // THIS IS REACHED
      console.log('map loaded');
The map is completely failing to load (as expected), but for some reason load doesn't reject in 4.0 and 4.1.
Is this a bug or by design?
Cheers,
Martijn
