map.infoWindow marker symbol does not show up in JSAPI 3.14
11962
24
09-28-2015 12:54 PM
BillyYancey
I switched my JSAPI version to 3.14 and now, when I have point features selected, the symbol does not show up. It works fine if I only switch back to 3.12. It also works fine for the line features.
Interestingly enough, I could not find any of the samples in which point features are highlighted when popups are used on a point features identify style tool.
Here is the current symbol setup in case it it helps:
selColor = new esri.Color([0, 255, 255, 0.6]);
selLine = new esri.symbol.CartographicLineSymbol(esri.symbol.CartographicLineSymbol.STYLE_SOLID, selColor, 10, esri.symbol.CartographicLineSymbol.CAP_ROUND, esri.symbol.CartographicLineSymbol.JOIN_ROUND);
selMarker = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 20, selLine, selColor);
mainMap.infoWindow.lineSymbol = selLine;
mainMap.infoWindow.markerSymbol = selMarker;
BillyYancey
I think I have found the cause of the issue which is a bug in JS-API 3.14. How can I report and get this fixed? Any admins here?
KenBuja
MVP Esteemed Contributor
To bring something to the attention of the JavaScript developers, it would help if you move this to the ArcGIS API for JavaScript​ space instead of the more generic Developers space. You can also use the @ symbol and start typing the name of one of the Javascript experts (like Bjorn Svensson​ orKelly Hutchins​) to bring this to their attention.
You should be able to log a bug using Esri's support page, logging in with your global account.
KellyHutchins
Esri Notable Contributor
To report bugs with the JSAPI please contact Esri Technical Support
LauraMiles1
Did you get any resolution to this? I think I may be having the same issue in 3.15.
sreeharikottoormadam
I have the same issue with 3.15. Is anyone found resolution to this?
   var pointHighlightSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98,194,204]), 2), new Color([98,94,204,0.8]));
    var polyFillSymbol= new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]));
    popup = new Popup(
        { fillSymbol: polyFillSymbol, markerSymbol: pointHighlightSymbol },
        domConstruct.create("div"));
KellyHutchins
I created a quick test using a feature layer with points and a simple marker symbol and setting the popup to an alternate symbol worked for me in version 3.15.  Here's the relevant code:
       var symbol = new SimpleMarkerSymbol({
              "color": [0,0,0,1],
              "size": 12,
              "angle": -30,
              "xoffset": 0,
              "yoffset": 0,
              "type": "esriSMS",
              "style": "esriSMSCircle",
              "outline": {
                "color": [255,0,191],
                "width": 2,
                "type": "esriSLS",
                "style": "esriSLSSolid"
            map.infoWindow.set("markerSymbol", symbol);
Here's a link to a js bin showing the working sample:
JS Bin - Collaborative JavaScript Debugging
LauraMiles1
Hi Kelly, I tried this out but unfortunately it doesn't seem to work. Here's a jsfiddle​
Edit: corrected the missing reference in the jsfiddle
Hi Kelly, It is not working when combined with identify tool. I think the issue is with geometry to highlight the individual feature.
KellyHutchins
There's a sample in the help showing custom symbology with Identify task. I tested it out and it worked just fine. In the example the fill symbol is customized because the geometry type being selected is polygon.
Display identify results in popup | ArcGIS API for JavaScript
