Map graphics Selection
1371
05-07-2012 10:54 PM
praveenraorane
How to get existing map graphics selection along with its attribute i.e layername,objectid ...
TomJacoby
var lastSelectedGraphic;
function init() {
 ** Do your init work here...
 map.graphics.enableMouseEvents();
 dojo.connect(map.graphics, "onClick", function(evt) {
  lastSelectedGraphic = evt.graphic;
  // You can do more work with the graphic here, but it is also stored for access anytime time later.
init();
From there you can get what you need, I think.
praveenraorane
thanks tom for your response
the selection is not happening through mouse.
the problem is the map graphics are nothing but query results, which is a result of query fired or tracing operation performed.
function init() {
init();
