map-component api
1532
05-03-2024 07:24 AM
MKY
Does the arcgis map component only works with WebMap? How can I add a feature layer service to a map-component?
ReneRubalcava
Esri Frequent Contributor
The map and scene components have a map property that you can reference to add layers.
https://developers.arcgis.com/javascript/latest/components/storybook/?path=/docs/map-components_comp...
In the "next" version, which will be in 4.30, we added a method on the elements for addLayer and addLayers.
async function load() {
	const Layer = await $arcgis.import("esri/layers/Layer");
	const url =
		"https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/2";
	const layer = await Layer.fromArcGISServerUrl({
		url
	// Reference the map component
	const mapElem = document.querySelector("arcgis-map");
	mapElem.addEventListener("arcgisViewReadyChange", () => {
		// works today
		// mapElem.map.add(layer);
	}, { once: true });
	// available in next, will be in 4.30
	mapElem.addLayer(layer);
load();
Here is a codepen.
https://codepen.io/odoe/pen/NWowrmo?editors=0010
ReneRubalcava
	const url =
		url
		// works today
	}, { once: true });
load();
Here is a codepen.
