Map.CenterAndZoom Issue
4412
03-06-2014 02:01 AM
NikitaWachstaub
Good day,
I cannot get a center and zooming funktion in my JS-Viewer. Hier is the code:
function DrawPointAndZoom() {
        try {
            var mylat = 29.818008;
            var mylong = 5.423178;
            var latLongPoint = new esri.geometry.Point(mylat, mylong, new esri.SpatialReference({ wkid: 4326 }));
            var mercator = esri.geometry.geographicToWebMercator(latLongPoint);
            map.centerAndZoom(mercator, 10)
        catch (err) {
            alert(err);
I get an error:    TypeError: map.centerAndZoom is not a function
What can be the problem?
NikitaWachstaub
KenBuja
MVP Esteemed Contributor
Can you post your code or a working sample at JSBin that shows the problem?
NikitaWachstaub
The problem is already solved)
JacquelineKovarik
Can you please post the solution here?
KeithGanzenmuller
What was the solution?
