Magnifier Problem
761
04-21-2025 01:21 AM
SaiPeketi
I'm using Arcgis SDK JS v4.31.6 with Angular v18. I've implemented the magnifier tool in my code. It's working fine for the past few days, but currently I'm getting an error of "EsriGlobalErrorHandling.ts:87 ERROR Error: Failed to find uniform value for transform.dvs" in Dev Env. It's working fine in other environments and localhost, but I'm not sure what the issue is with the error message to resolve. Can anyone suggest to me some way to debug or find the root cause to fix it?
Thanks in advance.
Andy
Noah-Sager
I haven't seen this error before with the ArcGIS Maps SDK for JavaScript. I would try to simplify the issue. Can you reproduce the issue in Dev Env with only the ArcGIS Maps SDK for JavaScript? Is your Dev Env using a modern OS and graphics card?
