Looking to keep cached base map at full extent even when the browser is minimized
4690
7
06-23-2015 12:05 PM
IanPeebles
I have an application that works well, yet I am trying to get the map to appear at full scale when the browser is opened in a minimized window.  When the browser is opened at a maximized browser window, the map does appear at full extent.
is there a way I can scale the map at full extent when the browser is minimized?  I understand that this may be a css issue.  Below are samples I am referring to?
Browser - Full Extent
Browser - Minimized Window
Notice the difference?
There are going to be users that open their browser in a minimized state, but I want them to be able to see the entire extent of the City.  Also, there is a cached base map used.
Anyone have any ideas?
IanPeebles
Ken,
I tried this out and I could not get it to work.  Here is the block of code I use for the map:
   // MAP START EXTENT
   var startExtent = new Extent(2080000, 216000, 2200000, 280000, new SpatialReference({wkid: 102724}));
   // MAP
      map = new esri.Map("map", {
          extent: startExtent,
          sliderPosition: "top-left",
          sliderOrientation: "horizontal",
          sliderStyle: "large",
          isZoomSlider: true
How would I incorporate your suggestion?
RobertScheitlin__GISP
Ian,
   In your "minimized state" what happen when someone clicks the home button (full extent button)?
IanPeebles
Robert,
All it does is move the map to the max scale of 1:12000 and centers the current scale in the map.  I am just wondering if the map frame can some how adjust according to browser window size?
With a dynamic map service, this is not a problem
Ian
KenBuja
MVP Esteemed Contributor
When you're using the tile map layer, you're going to run into the issue when the extent of the service won't exactly fit to the size of the browser window. It will either be too large or two small. The map's setExtent method does have a way around this, however. It has an optional parameter that makes sure the extent you use will fully fit in the window. It defaults to false, so you just have to set it to true.
map.setExtent(initialExtent, true);
IanPeebles
Ken,
   // MAP START EXTENT
   // MAP
          isZoomSlider: true
TimWitt2
Ian,
when you create the map you can add the following, just put it below your extent: startExtent,
fitExtent: true
This does the same thing Ken is talking about, but on map creation.
But remember this will only work if the window is already minimized when they load your map.
Tim
KenBuja
It's not necessarily due to the map being minimized or maximized. Someone using the site with a screen resolution that is different that what Ian is developing would see this problem even if the screen is maximized. It's all about the pixel size of the browser window.
IanPeebles
Hey Tim, thanks for the response.  I tried your suggestion, but I still do not have the map at full extent when the browser is minimized.  Here is my code and a screen shot:
   // MAP
          fitExtent: true,
    isZoomSlider: true
Anything else I should try?
