Location widget , visualising location accuracy
1170
04-14-2022 06:27 AM
LakshmiPriyadharshini
Is it possible to show location accuracy in map like location headsup while rotating mobile as it is shown in below image?
Please provide the solution to get this 'blue-cone' in arcgis map.
ReneRubalcava
Esri Frequent Contributor
This was kind of fun to do. Geolocation coordinates return an accuracy in meters.
https://developer.mozilla.org/en-US/docs/Web/API/GeolocationCoordinates/accuracy
You can use this value with the view resolution to figure out the size of the marker you want to display.
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-View.html#resolution
I think I did this math right, I'm sure someone will correct if I didn't.
track.on("track", ({ position }) => {
    accuracy = position.coords.accuracy;
    currentCoords = position.coords;
    // divide accuracty (meters) by maps resolution (pixels)
    const size = `${accuracy / view.resolution}px`;
    symbol.size = size;
    layer.removeAll();
    layer.add({
    geometry: {
        type: "point",
        latitude: currentCoords.latitude,
        longitude: currentCoords.longitude
    symbol
https://codepen.io/odoe/pen/zYpmEMB?editors=1000
The Geolocation API also returns a heading you can use to rotate you symbol, which would be simplest, or you could calculate how to draw a short line in that heading. I'll leave that up to you.
https://developer.mozilla.org/en-US/docs/Web/API/GeolocationCoordinates/heading
