Localization/customization of Pop-up window
3018
07-07-2011 03:37 AM
AW1
I'm having trouble changing the default text strings on the Pop-up window.
I'm following the instructions found here:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/inside_bundle.html
But it seems to have no effect. I can detect that for example the variable esri.bundle.widgets.popup.NLS_noInfo gets changed from 'No information available' to my custom string, but the popup in the map still shows 'No information available'.
Any ideas?
Thanks in advance!
SaurabhGupta
I used the following code in my init and was able to see the strings change.
esri.bundle.widgets.popup.NLS_searching = "Looking..."
esri.bundle.widgets.popup.NLS_noAttach = "Nothin here!";
I am also attaching the sample code.
Hope this helps.
SiqiLi
by Esri Contributor
Hope this helps.
Hi Saurabh,
I was actually wondering how to do this too. Thanks for the post. It works.
AW1
Hope this helps.
Thanks a lot! I got it to work. I looked in your example to see what I did different, and it turned out that changing the variables at the top of the init function (like you did) worked, whereas I originally tried to change them at the end of the init function.
Thanks again!
