Loading KML layer gives duplicate sublayers
1449
02-06-2022 01:39 AM
HanochS
I have an issues with loading and showing kml layers in LayerList widget . The issue is that I can see that the LayerList is  duplicating the layer name and can see it as a sub layer.
I tried to do the same in arcgis online sample code and I got the same results.
this is the layer I am trying to load but basically it s happening for all kml layers
"https://googlearchive.github.io/js-v2-samples/ggeoxml/cta.kml"
I attached the result.
UndralBatsukh
Hi there,
You can hide the sublayers in the layerList by setting the KMLLayer's listMode to hide-children.
UndralBatsukh
OK I see what you are saying. We will create an issue for this and will let you know once we resolve it.
-Undral
