Loading icon on query
5074
9
10-30-2020 08:01 AM
JaredPilbeam2
I'm having trouble adding a loading icon to this app. I want it to appear when the user makes a query. In the map, the points change to whatever category or item_keyword the user selects from the two drop-downs. As it stands, after making a selection the user can't tell when the process completes.
I'm able to display a loading icon for the map view as this example demonstrates, but I'm not sure how to do it on a query.
Here's the section of my app dealing with queries:
// query all features from the recycle layer
    view
        .when(function () {
            return recycleLayer.when(function () {
                var query = recycleLayer.createQuery();
                return recycleLayer.queryFeatures(query);
        .then(getValues)
        .then(getUniqueValues)
        .then(addToSelect);
    // re-query the layer based on the selected Category and re-populate the keyword select
    catTypeSelect.addEventListener("change", function () {
        var sqlExp = "";
        if (catTypeSelect.selectedIndex > 0) {
            sqlExp +=
                "Category LIKE '%" +
                catTypeSelect.options[catTypeSelect.selectedIndex].value +
        query.where = sqlExp;
        recycleLayer
            .then(getValues2)
            .then(getUniqueValues2)
            .then(addToSelect2);
        setDefinitionExpression();
    keyTypeSelect.addEventListener("change", setDefinitionExpression);
    // return an array of all the values in the
    // Category and item_keyword fields of the Recycle layer
    function getValues(response) {
        var features = response.features;
        var values = features.map(function (feature) {
            return {
                Category: feature.attributes.Category,
                item_keyword: feature.attributes.item_keyword
        return values;
    function getValues2(response) {
            return feature.attributes.item_keyword;
        return values;
    // return an array of unique values in
    // the item_keyword and Category fields of the Recycle layer
    function getUniqueValues(values) {
        var uniqueKeyValues = [];
        var uniqueCatValues = [];
        values.forEach(function (item, i) {
            var keyVal = item.item_keyword.split(";");
            var catVal = item.Category.split(";");
            catVal.map(function (val1) {
                if (
                    (uniqueCatValues.length < 1 ||
                        uniqueCatValues.indexOf(val1) === -1) &&
                    val1 !== ""
                    uniqueCatValues.push(val1);
            keyVal.map(function (val2) {
                if (
                    (uniqueKeyValues.length < 1 ||
                        uniqueKeyValues.indexOf(val2) === -1) &&
                    val2 !== ""
                    uniqueKeyValues.push(val2);
        return {
            uKeyVals: uniqueKeyValues,
            uCatVals: uniqueCatValues
    function getUniqueValues2(values) {
            var keyVal = item.split(";");
                if (
                    val2 !== ""
        return uniqueKeyValues;
    // Add the unique values to the recycle type
    // select element. This will allow the user
    // to filter categories by type.
    function addToSelect(values) {
        var dOpt = document.createElement("option");
        dOpt.value = "";
        dOpt.selected = true;
        dOpt.text = "Select one";
        catTypeSelect.add(dOpt);
        values.uCatVals.sort();
        values.uCatVals.forEach(function (value) {
            var option = document.createElement("option");
            option.text = value;
            catTypeSelect.add(option);
        var dOpt2 = document.createElement("option");
        dOpt2.value = "";
        dOpt2.selected = true;
        dOpt2.text = "Select one";
        keyTypeSelect.add(dOpt2);
        values.uKeyVals.sort();
        values.uKeyVals.forEach(function (value) {
            keyTypeSelect.add(option);
        return setDefinitionExpression();
    function addToSelect2(values) {
        while (keyTypeSelect.options.length > 0) {
            keyTypeSelect.remove(0);
        dOpt2.value = "";
        dOpt2.disabled = true;
        values.sort();
        values.forEach(function (value) {
        return true;
    // set the definition expression on the recycle
    // layer to reflect the selection of the user
    function setDefinitionExpression() {
        var sqlExp = "";
            sqlExp +=
        if (keyTypeSelect.selectedIndex > 0) {
            if (sqlExp === "") {
                sqlExp +=
                    "item_keyword LIKE '%" +
                    keyTypeSelect.options[keyTypeSelect.selectedIndex].value +
            } else {
                sqlExp +=
                    " AND item_keyword LIKE '%" +
        if (resRb.checked) {
            if (sqlExp !== "") {
                sqlExp += " AND USER_IsRes = 'TRUE'";
        } else {
                sqlExp += " AND USER_IsBus = 'TRUE'";
        console.info(sqlExp);
        recycleLayer.definitionExpression = sqlExp;
        if (!recycleLayer.visible) {
            recycleLayer.visible = true;
        return queryForGeometries();
    // Get all the geometries of the recycle layer
    // the createQuery() method creates a query
    // object that respects the definitionExpression
    // of the layer
    function queryForGeometries() {
        console.log("Running query");
        var rQuery = recycleLayer.createQuery();
        return recycleLayer.queryFeatures(rQuery).then(function (response) {
            rGeometries = response.features.map(function (feature) {
                return feature.geometry;
            return rGeometries;
    filterButton.addEventListener("click", function () {
RobertScheitlin__GISP
No there isn't. Just simply add the
domClass.add('loadingDiv', 'visible');
before
        recycleLayer
and remove it in the addToSelect2 method as I mentioned before.
Jared,
   You show the div when you right before you execute the query.
domClass.add('loadingDiv', 'visible'); and then in your results function (the last one addToSelect2) you hide it.
JaredPilbeam2
Thanks Robert,
It's apparently a pretty simple operation, but where exactly to put this stuff is not really popping out at me. Is there not an example somewhere?
before
        recycleLayer
JaredPilbeam2
Thanks!
For posterity:
        domClass.add('loadingDiv', 'visible'); //add loadingDiv here
        recycleLayer
            .then(getValues2)
select
            domClass.remove('loadingDiv', 'visible'); //remove loadingDiv here
JaredPilbeam2
Robert,
Sorry to drag you back into this one. I was wondering how to get the loading div to show when you query both the Category and item_keyword? Right now, the div shows for the Category only.
Jared,
   Can you post your full code so I can see what you have done?
JaredPilbeam2
    view
        .when(function () {
        .then(getValues)
        .then(addToSelect);
        var sqlExp = "";
            sqlExp +=
        recycleLayer
            .then(getValues2)
            return {
        return values;
    // re-query the layer based on the selected item_keyword and re-populate the keyword select
        return values;
                if (
                    val1 !== ""
                if (
                    val2 !== ""
        return {
                if (
                    val2 !== ""
        dOpt.value = "";
        dOpt2.value = "";
        dOpt2.value = "";
        values.sort();
        return true;
        var sqlExp = "";
            sqlExp +=
                sqlExp +=
            } else {
                sqlExp +=
        } else {
    // of the layer
            return rGeometries;
function setDefinitionExpression() {‍
‍‍‍‍    function queryForGeometries() {
            return rGeometries;
JaredPilbeam2
Perfect. Thanks a lot.
