Load select layers into templatePicker
1202
04-02-2014 07:24 AM
williamcarr
Greetings,
I'm throwing together an app to add a series (107) feature layers for the attribute inspector. I also have a Editor/Template for adding point features. The problem is that the template picks up all the feature layers that are loaded.
var templateLayers = arrayUtils.map(evt.layers, function(result){
            return result.layer;
Is there a way to only display a couple feature layers for the template picker? I don't want to clutter the content pane and REALLY don't want anybody contaminating the other feature layers. I've checked samples and examples all day but, no joy.
Any ideas?
TimCollyer
Sounds like you want to use filter instead of map?
http://dojotoolkit.org/reference-guide/1.9/dojo/_base/array.html#filter
I think your code would look something like this
var templateLayers = arrayUtils.filter(evt.layers, function(result){
                        return result.layer.id == "id of layer you want";
williamcarr
Found the answer after a couple more looks at it.
I pulled the
out completely. and changed
featureLayers: templateLayers,
to
featureLayers: [layer,layer2,layer3]
Tim's filter worked, but I was running too many layers(my best guess) and it was causing a timeout.
Cheers.
