List Existing Graphics Points Based On Closest Distance To a Click Event
2031
09-28-2017 02:00 PM
BehrouzHosseini
Can you please take a look at this Demo and code and let me know how I can get a list of point graphics based on the closest distance to the click event position?
require([
          "esri/map",
          "esri/SpatialReference",
          "esri/graphic",
          "esri/layers/GraphicsLayer",
          "esri/geometry/Point",
          "esri/symbols/SimpleMarkerSymbol",
          "esri/symbols/SimpleFillSymbol",
          "dojo/domReady!"
  function(
          Map,
          SpatialReference,
          Graphic,
          GraphicsLayer,
          Point,
          SimpleMarkerSymbol,
          SimpleFillSymbol
      var map = new Map("map", {
          basemap: "streets",
          center: [-122.4, 37.785],
          zoom: 14,
    var graphicsLayer = new GraphicsLayer();
    var Symbol = new SimpleMarkerSymbol();
    graphicsLayer.add(new Graphic(new Point(-122.4, 37.777, new SpatialReference({ wkid: 4326 })), Symbol));
    graphicsLayer.add(new Graphic(new Point(-122.4, 37.785, new SpatialReference({ wkid: 4326 })), Symbol));
    graphicsLayer.add(new Graphic(new Point(-122.39,37.785, new SpatialReference({ wkid: 4326 })), Symbol));
    graphicsLayer.add(new Graphic(new Point(-122.41,37.785, new SpatialReference({ wkid: 4326 })), Symbol));
    graphicsLayer.add(new Graphic(new Point(-122.4, 37.793, new SpatialReference({ wkid: 4326 })), Symbol));
    map.addLayer(graphicsLayer);
    map.on("click", function(evt){    });
RichardReinicke
Hi Bengi Geoca‌,
the above mentioned answer should work fine. Just as an alternative if you don`t want to generate further web requests or you`re looking on a more client side solution then please have a look at this code:
require([
  "esri/map",
  "esri/graphic",
  "esri/geometry/webMercatorUtils",
  "esri/geometry/geometryEngine",
  "dojo/domReady!"
  function(
    Map,
    SpatialReference,
    Graphic,
    GraphicsLayer,
    Point,
    SimpleMarkerSymbol,
    SimpleFillSymbol,
    WebMercatorUtils,
    GeometryEngine
        basemap: "streets",
        zoom: 14
      map.on("click", function(evt) {
        var distances = [];
        var graphicsLayer = this.getLayer('graphicsLayer1');
        var highlightSymbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([255,0,0]));
        for (var i = 0; i < graphicsLayer.graphics.length; i++) {
          distances.push({
            index: i,
            distance: GeometryEngine.distance(
                        evt.mapPoint,
                        WebMercatorUtils.geographicToWebMercator(graphicsLayer.graphics[i].geometry),
                        "meters")
        var sortedDistances = distances.sort(function(a, b) {
                                return a.distance - b.distance; });
        graphicsLayer.graphics[sortedDistances[0].index].setSymbol(highlightSymbol);
Jean-MarcRoy1
Hi @Bengi Geoca,
You can use GeometryEngine and more specifically the nearestCoordinate method to find the closest point of a Multipoint geometry.
Here is an example with the latest JS API 4.4 : Arcgis JS API 4.4 : nearest point - JSFiddle .
You can take inspiration from this code it would be very similar with 3.x version.
Hope it helps!
RichardReinicke
Hi Bengi Geoca‌,
require([
  "esri/map",
  "esri/graphic",
  "dojo/domReady!"
  function(
    Map,
    SpatialReference,
    Graphic,
    GraphicsLayer,
    Point,
    SimpleMarkerSymbol,
    SimpleFillSymbol,
    WebMercatorUtils,
    GeometryEngine
        basemap: "streets",
        zoom: 14
        var distances = [];
          distances.push({
            index: i,
                        evt.mapPoint,
                        "meters")
