List ArcGIS Server folders with ESRI request
6342
13
10-12-2015 10:31 AM
AlexGole
Hi all, I am trying to build this application that lists all web services within each ArcGIS Server folders. I am trying to programmatically feed a drop down list with ArcGIS Server folder's names so the user just has to select the folder of his choice and it returns all services in  a table. The following code works great but I had to manually enter each folder:
<!DOCTYPE html>
<html>
<head>
    <title>Service Info</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <link rel="stylesheet" href="https://cdn.datatables.net/1.10.9/css/jquery.dataTables.min.css">
    <style>
        html, body, #details {
            padding: 0;
            margin: 0;
            height: 100%;
        .dgrid-cell-padding {
            padding: 10px !important;
        .dgrid {
            height: 100% !important;
        .dgrid-cell{
            border:1px solid black !important;
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script src="//code.jquery.com/jquery-1.11.3.min.js"></script>
    <script src="https://cdn.datatables.net/1.10.9/js/jquery.dataTables.min.js"></script>
    <script>
        require([
          "esri/request",
          "dojo/_base/array",
          "dojo/dom",
          "dojo/domReady!"
        ], function (esriRequest, array, dom, Grid) {
            $(document).ready(function () {
                var baseUrl = "http://webgisdevint1/arcgis/rest/services";
                $('.selectpicker').on('change', function(){
                    var baseFolder = $(this).find("option:selected").val();
                esriRequest({
                url: baseUrl + "/" + baseFolder,
                content: {
                    "f": "json"
                callbackParamName: "callback"
            }).then(function (response) {
                var data = array.map(response.services, function (service, index) {
                    return {
                        "url": "<a target='_blank' href='" + baseUrl + "/" + service.name + "/" + service.type + "'>" + baseUrl + "/" + service.name + "/" + service.type + "</a><br>",
                        "name": service.name,
                        "type": service.type,
                        "id": index
                $('#example').DataTable({
                    destroy: true,
                    data: data,
                    columns: [
                        { title:"URL", data: "url" },
                        { title: "Name", data: "name" },
                        { title: "Type", data: "type" }
    </script>
</head>
<body class="claro">
    <select class="selectpicker">
        <option>Search web GIS Folders:</option>
        <option>Alex_Try</option>
        <option>CalMAPPER</option>
        <option>davin</option>
        <option>ForestPractice</option>
        <option>FRAP</option>
        <option>Pipeline</option>
        <option>PPFIS</option>
        <option>ResourceMgmt</option>
        <option>System</option>
        <option>testing</option>
        <option>Utilities</option>
        <option>WatershedMapper</option>
    </select>
    <table id="example" class="display" width="100%"></table>
</body>
</html>
Any idea is more than welcome,
Alex
AlexGole
I am actually running it from my localhost on my IIS7.5 (in domain registered computer). And using my own Server's URL. Any idea?
AlexGole
As you can see on JSbin, I am experiencing about the same problem: https://jsbin.com/zomerizeme/edit?html,output
RobertScheitlin__GISP
Alex,
  The problem is the lack of a specified callback on the first esriRequest.
The mixture of https and http urls does not help either (line 10 and 35 was https) line 35 did not specify a protocol at all. Line 51 and 52 added.
<!DOCTYPE html>
<html>
<head>
  <link rel="stylesheet" href="http://cdn.datatables.net/1.10.9/css/jquery.dataTables.min.css">
  <style>
    html,
    body,
    #details {
      padding: 0;
      margin: 0;
      height: 100%;
    .dgrid {
    .dgrid-cell {
      border: 1px solid black !important;
  </style>
  <script src="http://code.jquery.com/jquery-1.11.3.min.js"></script>
  <script src="http://cdn.datatables.net/1.10.9/js/jquery.dataTables.min.js"></script>
  <script>
    require([
          "esri/request",
          "dojo/_base/array",
          "dojo/dom",
          "dojo/domReady!"
        ], function (esriRequest, array, dom) {
        var baseUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services";
        esriRequest({
          url: baseUrl + "/",
          content: {
            "f": "json"
          handleAs: "json",
        }).then(function( response ){
          $.each(response.folders, function (index, value) {
            $('.selectpicker').append($('<option>', {
              value: value,
              text: value
          $(".selectpicker").val($(".selectpicker option:first").val()).change();
        $('.selectpicker').on('change', function () {
          esriRequest({
            content: {
              "f": "json"
            handleAs: "json",
            var data = array.map(response.services, function (layer, index) {
              return {
                "url": "<a target='_blank' href='" + baseUrl + "/" + baseFolder + "/" + layer.name + "'>" +
                baseUrl + "/" + baseFolder + "/" + layer.name + "/</a><br>",
                "name": layer.name,
                "id": index
              destroy: true,
              data: data,
              columns: [
                  title: "URL",
                  data: "url"
                  title: "Name",
                  data: "name"
  </script>
</head>
  <select class="selectpicker" prompt="Search web GIS Folders:">
  </select>
  <table id="layers" class="display" width="100%"></table>
</body>
</html>
AlexGole
That was it thank you Robert!It works great!
