Link to previous JS API reference
3173
6
08-09-2023 10:54 AM
WalterEralio
IS there a link to the previous API references (not just the latest one) , or a place to download it?
Trying to get 4.24 (and 4.26)
AyanPalit
@WalterEralio Please check Ken's post on the archived download links here
Ayan Palit | Principal Consultant Esri
KenBuja
MVP Esteemed Contributor
You can find the previous versions of the documentation to download here.
AyanPalit
@WalterEralio I usually start with the Release notes for example:  https://developers.arcgis.com/javascript/latest/4.24/
At the feature level, you can simply search for the item and there is a note on version introduced:
WalterEralio
Thanks for the suggestion.. but I was more into looking for a sort of archiving of previous (latest) API reference in the same way we have the 4.27 now (for example all dojo was fully removed lately therefore snippets, samples etc would not be the same for 4.24 than 4.27).. or updated widgets etc...
AyanPalit
GaryB
Is there really no way to see the documentation for the previous release online?  For example, the documentation for the current version is https://developers.arcgis.com/javascript/latest/api-reference/, is it not possible to somehow change the URL to be something like https://developers.arcgis.com/javascript/4.3.1/api-reference?  Maybe I'm just not seeing some obvious way to get to this. Thanks!
AdrianMarsden
Honored Contributor
Given that there is still 3.x stuff around it is really rubbish that Esri have removed all documentation prior to the new 5.x - even if we all had time to migrate NOW, we'd still need easy access to the old documentation to see how things work in older versions.
Please reconsider
