Line Rendering Problem (Feature Layer vs Dynamic Layer)
2447
08-24-2012 06:43 AM
AR
I'm going crazy here.
When I add a map as a FeatureLayer, the lines are rendered on top of each other (incorrect), however when added as a DynamicLayer, it's displayed just how it's displayed in ArcMap (correct).
Here's my simple simple code:
var myURL = "http://..."
var fl = new esri.layers.FeatureLayer(myURL+ /layerIndex)
var dl = new esri.layers.ArcGISDynamicMapServiceLayer(myURL)
map.addLayer(fl)
map.addLayer(dl)
Please look at my attachments to get a better idea. You can ignore the red lines on dynamicLayer.png. What's important are the black lines.
Aaron
AR
Did some digging, and found my answer-
If you define your lines as cartographic lines in ArcMap, and proceed to call them in a feature layer on your client side javascript, the cartographic lines get "downgraded" to simple lines.
...Anyone out there find a workaround?
Here's the passage and article:
For line layers, simple line symbols are supported. If other symbols are used, the feature service downgrades them to simple line symbols. For example, a cartographic line symbol in the map document may be drawn as a simple solid line in a feature service client. Also, if a line symbol has multiple layers, the feature service considers only the top layer.
Quote from article: http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#//009300000021...
