Light Gray Canvas Map
1589
10-04-2011 10:22 AM
MarkHoover
Are there any plans to add the Light Gray Canvas Map (as discussed here) to the Basemap Gallery?  Or can we already access it (and if so, is there a trick to doing so)?
derekswingley1
No plans yet.
You could add it to the default basemap gallery with something like this:
function createBasemapGallery() {
  //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
  var basemapGallery = new esri.dijit.BasemapGallery({
    showArcGISBasemaps: true,
    bingMapsKey: 'Av1bH4keF8rXBtxWOegklgWGCYYz8UGYvBhsWKuvc4Z15kT76xVFOERk8jkKEDvT',
    map: map
  }, "basemapGallery");
  basemapGallery.startup();
  dojo.connect(basemapGallery, 'onLoad', function(bm) {
    // find a base map to remove
    // in this case, it'll be the one named "Terrain"
    var bm = dojo.filter(basemapGallery.basemaps, function(bm) {
      return bm.title == 'Terrain';
    })[0];
    // remove the basemap from the gallery
    basemapGallery.remove(bm.id);
    // create a BasemapLayer and Basemap with the
    // ligh gray basemap
    var grayLayer = new esri.dijit.BasemapLayer({
      url:"http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"
    var grayBasemap = new esri.dijit.Basemap({
      layers:[grayLayer],
      title:"Light Gray",
      thumbnailUrl:"http://www.arcgis.com/sharing/content/items/8b3d38c0819547faa83f7b7aca80bd76/info/thumbnail/lightgray_thumb_webmap2.png"
    // add the light gray basemap
    basemapGallery.add(grayBasemap);
Or you can manually add it by building your own basemap gallery, see this sample:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/widget_basemapManual.html
MarkHoover
Perfect, thanks, Derek.
Robert_LeClair
Esri Esteemed Contributor
Mark - it would appear that the Light Gray Canvas is in the 10.1 Beta Basemap gallery.  But for 10.0 clients, Derek's approach works well.
Robert LeClair
Esri-Denver
