Legend Widget symbol opacity override
1348
02-27-2024 12:04 PM
AnthonyThompsonFWP
Is there a way to override the opacity of a symbol displayed in the Legend widget without altering the layer's opacity? A partially transparent layer's symbol is darkened significantly by a dark widget background when displayed as a symbol in the Legend with our branded dark background.
Thanks!
MatthewDriscoll
Here is a working codepen example.  I have the timeout set really high so you will need to wait around 15-30 seconds to see the opacity change on the 4th item in the legend.
https://codepen.io/mbdriscoll/pen/XWQWexm
MatthewDriscoll
You need to change the opacity of the class esri-legend__symbol.
MatthewDriscoll
AnthonyThompsonFWP
Thank you for the suggestion and example!
