Legend widget remove no legend message
4412
6
01-27-2019 02:47 AM
AnjithaSenarath3
I am working on Arabic Javascript Application (API 4.10)   with Legend inside the layer list .  the code as below at the moment for layerlist
var layerList = new LayerList({
view: view,
listItemCreatedFunction: function (event) {
const item = event.item;
if (item.layer.type != "group"){ // don't show legend twice
item.panel = {
content: "legend",
open: true
code is working fine but it shows No Legend in English for Arabic Application. I want to get rid of "No Legend" default message  Information. How Do I do this  (I aslo dont wanted to convert that massage data to arabic as user dosnt want) .
How to remove it ?  Please see screen capture. Kindly help
No legent message
RobertScheitlin__GISP
It is as simple as adding this css rule:
.esri-legend__message {
  display: none;
  display: none;
AnjithaSenarath3
That is awesome. Thank you very much Robert
NicolasRoger
Hello Robert,
can this also be done for a widget that is created programmatically?
I added your css rule to the .css file of the custom widget that is creating a legend widget. The text is still not hidden.
I am using the 3.x api. Maybe this is the problem?
EDIT:
Nevermind I got it. It was:
.esriLegendMsg { visibility: hidden; }
by Anonymous User
Not applicable
Thank you for this post. I was able to hide the undesired text from the legend prior to loading the operational layers by adding the display properties for the div in my app as:
/* ALM added custom text to replace 'no legend default message */
#esri_dijit_Legend_0_msg {
  display: none;
However, is it possible to replace the text in the div with a hint such as "Use the Add Layer tool to create the Legend." from the API element (<div id="esri_dijit_Legend_0_msg" class="esriLegendMsg">No legend</div>)?
Thanks in advance for any suggestions,
A
Andra,
   You can access this through code and change the text using:
document.getElementById('esri_dijit_Legend_0_msg').innerHTML = "Blah blah";
RaoSona
I am also trying to modify the text "No Legend" to some other text. I am using 3x api. Have tried the suggestion above i.e.
in widget.html added:
In style.css, added
  display: none;
The above does not turn off the label, therefore I cannot change the text via code also. Am I missing something? Is this feasible ?
