Legend - toggle services in AMD
1385
02-07-2014 08:20 AM
TimWitt
Hey everybody!
Does anybody use the Legend - toggle services example in AMD format?
I tried to include it in my app, but I'm pretty new to JavaScript and this one is a head scratcher 🙂
Here is what I've got so far for that part of my code:
      var legendLayers = [];       var county = new FeatureLayer("http://gis.brevardcounty.us/gissrv/rest/services/Base_Map/General_WKID102100/MapServer/6",{         mode: FeatureLayer.MODE_ONDEMAND,         outFields:["*"]       });              //Create Legend       map.on("layers-add-result", function (evt) {         var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {           return {layer:layer.layer, title:layer.layer.name};         });         if (layerInfo.length > 0) {           var legendDijit = new Legend({             map: map,             layerInfos: layerInfo           }, "legendDiv");           legendDijit.startup();         }       });       map.addLayers([county]);       legendLayers.push({layer:county, title:"County"});      //Create Checkboxes       map.on("layers-add-result", function (evt) {         arrayUtils.map(legendLayers, function (evt) {           var layerName = layer.title;           var checkBox = new CheckBox ({             name:"checkBox" + layer.layer.id,             checked: layer.layer.visible,             onChange: function (evt) {               var clayer=map.getLayer(this.value);               clayer.setVisibility(!clayer.visible);               this.checked = clayer.visible;             }           });           //Move the checkboxes to TOC           domConstruct.place(checkBox.domNode, dom.byId("toggle"), "after");           var checkLable = domConstruct.create('label', {'for':checkBox.name, innerHTML:layerName}, checkBox.domNode, "after");           domConstruct.place("<br />", checkLabel, "after");         });                });
If you used that example in AMD it would be nice to see working code.
Thanks
Tim
KenBuja
MVP Esteemed Contributor
Take a look at this post, where I set up a Fiddle with the sample written in AMD.
You might be interested in alternate ways of showing the legend and table of contents. There are a few widgets that integrate the TOC with the legend, like this one written by Nliu and this one by Matt Driscoll.
KenBuja
TimWitt
Thanks for the answer Ken.
I'm pretty new to the JavaScript API and I think that leads me to trying to re-invent the wheel 🙂
