Legend Symbols for Secure ArcGISDynamic Map Service Layer not showing
1133
07-31-2012 10:10 AM
suhanatssuhanats
I have read blogs before where it says that this problem has been solved with SP1. But I have not been able to make my legend symbols show although I am in SP4.
If some of you have make it work, could you please share what you did to make the legend symbols for a dynamic map servicelayer show in the map.
i am on javascript api 2.8.
AndrewBrown1
Are you using a specific legend widget?
BenFousek
It was a change in the way the legend widget functions from 2.8 to 3.0+. Here's a forum post in which I faced the same issue:
http://forums.arcgis.com/threads/65481-Legend-problems-with-secured-services-when-migrating-to-3.0-3...
