LEGEND in Service REST JAVASCRIPT
1936
6
05-12-2010 12:37 PM
MartinChaves
there any way that you can see the legend or table of content created with the ArcView within the REST web service with JavaScript?
MartinChaves
thanks, but I need an example for JAVASCRIPT - PHP.
that is, to a SERVER APACHE.
nicogis
MartinChaves
Try changing the code, but I could not make it work.
What I need is a *. js to bring me the list of properties *. MXD project data and display it in a caption in an HTML page on an apache server.
Or else, as I can get that data in javascript code.
MartinChaves
has no properties calling code. NET or Java;
MartinChaves
ArcGIS JavaScript API v2.0 resolves this?, Saw some examples for version 2, running under ArcGIS Server 10?, Because try using the v2.0 API in ArcGIS Server 9.3 and did not work.
Is there any way to get the DVD of the ArcGIS Server API v2.0?
