legend: hideLayer for tiled map service
3793
6
08-17-2012 05:08 AM
HugoAhlenius
I am trying to hide some layers from a service, an ArcGIS 10.1 tiled map service. I am using 3.1 of the API...
My legend constructor looks like this:
geoLegend = new esri.dijit.Legend({    map:myMap,    layerInfos: [{layer:myLayer, title: 'My data', hideLayers: [0,1,2,3]}] },"legendDiv");
But the hideLayers part doesn't seem to stick... What am I doing wrong? Does this not work on tile service... ?
derekswingley1
Here's a modified version of the Legend sample that uses a tiled service and hides a single layer:  http://jsfiddle.net/wxC5k/
The key line is:
layerInfo[0].hideLayers = [1];
One thing to check is that your layer indexes in hideLayers correspond to valid layer indexes in your map service.
Edit: Wanted to clarify that my previous post in this thread was wrong, you can use hideLayers with tiled services.
derekswingley1
Tiled services are a flattened version of your data where all layers are baked into a set of images. Once your tiles are generated, you lose the ability to control individual layer visibility when adding your service to a map as a tiled layer (the tradeoff is less control for better performance).
If your data behind the tiles is still on your server, you can add your service as a dynamic map service, which gives you the ability to control each layer's visibility. Dynamic services work with hideLayers while tiled services do not.
HugoAhlenius
Hi Derek, thanks for the response. I was aware that I wouldn't be able to hide layers in the map view for a tiled service, but the legend is still dynamically rendered, when it is requested, right? I had some hope that one would still be able to hide some layers in the legend display! Should I enter this as a feature request on the ideas website?
derekswingley1
I'll double check on this and get back to you.
ReneRubalcava
Esri Frequent Contributor
Dereks solution below is way better than my css hack.
derekswingley1
The key line is:
HugoAhlenius
ok, thanks! - will need to experiment more with this... !
