Layers, Features and Services
1428
12-01-2016 11:45 AM
PedroMadrid
Hi everyone, exists any possibility of creating layers, feature classes and services using ONLY Rest services?
RobertScheitlin__GISP
Pedro,
   I am not sure what you mean by this. The JS Api uses rest services to add layers to the map. So your question is not very clear.
SarojThapa1
If you are asking, if we can create layers and feature classes using only REST services, then the answer is no. We create datasets, feature classes, and maps in ArcMap/ ArcCatalog and publish them as RESTful services. Later, we use ArcGIS API for Javascript to add those layers and services to the maps. REST Services offer easier and smoother way to connect and interact with the web maps.
JayantaPoddar
Not sure if I understood your question correctly. If the map is published as Feature service (Feature Access) with EXPORT option enabled, you can open the service in ArcMap and export data to a feature class.
Think Location
