LayerList with token protected layer
9439
13
05-20-2016 07:59 AM
MarcoRosa
Hi to all,
im going to set up Layer List in this way:
var llWidget = new LayerList({
                    map: map,
                    showLegend: true,
                    showOpacitySlider: true,
                    layers: [{
                        layer: mylayer,
                        subLayers: true
                }, "layerList");
                llWidget.startup();
Note that mylayer becomes from a request for a token protected lite this:
var mylayer= new ArcGISDynamicMapServiceLayer(url_mylayer + "?token=" + token, {})
Doesn't work .... error is invalid tokens when request to legends it's made. How can i set layer to layer list in thic case ?
Where's the mistake?
Thank's in advanced to all
GP
MarcoRosa
Hi Joel,
done that …. Added require "esri/dijit/Legend", and modified code following istructions. Protected are correctly added to map , no more errors were generated but legend doesnt work correctly.
I can view just first layer without detailed options (layer styles / opacity)
Now in trying to download and install local api …. We’ll see
Da: Joel Bennett
Inviato: lunedì 23 maggio 2016 14:58
A: Porta Giorgio
Oggetto: Re: - LayerList with token protected layer
GeoNet <https://community.esri.com/?et=watches.email.thread>
reply from Joel Bennett<https://community.esri.com/people/bennetjo?et=watches.email.thread> in ArcGIS API for JavaScript - View the full discussion<https://community.esri.com/message/610200?et=watches.email.thread#comment-610200>
JoelBennett
MVP Regular Contributor
Could you post the relevant portions of your code with the modifications included?  In the case that it is correct, there may also be some additional requires I didn't think of initially.
JoelBennett
Yes, looking at it more closely, you're better off setting up the API locally and tweaking the one file.  Trying the inline fix actually gets pretty nasty...those two functions are full of required modules...for example, in _legendRequestServer, I can see that:
c = dojo/_base/lang
l = dojo/json
d = dojo/_base/array
w = esri/request
There's more in the _buildRow_Tools function as well.  It's possible to work with this, but very ugly, so I wouldn't recommend it.  I apologize for sending you down that trail without fully thinking it through.
MarcoRosa
Hello Joel,
downloaded, installed local API and made workaround inside Legend.js as your suggestion, it works all fine.
Thanks a lot, hear from you soon,
Giorgio
Da: Joel Bennett
Inviato: lunedì 23 maggio 2016 18:47
A: Porta Giorgio
reply from Joel Bennett<https://community.esri.com/people/bennetjo?et=watches.email.thread> in ArcGIS API for JavaScript - View the full discussion<https://community.esri.com/message/610333?et=watches.email.thread#comment-610333>
